1999 throw out bearing question
I have a 99 Carrera with a 6-speed. I noticed a few weeks ago a whining noise - sort of like a belt slipping - when I give the car gas and start releasing the clutch pedal. I told my mechanic about it and he replaced the idle pulley. But the noise was still there. I took it back and asked him to let me drive him because maybe I'm not shifting properly.
Yes, he said I was giving it too much gas and shifting too quickly (from first to second). And then the noise happened. He immediately said throw out bearing but added that as long as it's not "clicking or rattling" I'm ok. Once I hear the clicking or rattling that's when I need to bring it in and since I drive this car weekends only I'm hoping it lasts a while before having to replace the throw out bearing.
But I also wanted opinions on this noise. None of the posts I've read have ever mentioned this lose belt-like noise being the throw out bearing. Everyone writes about rattling noises.
Has anyone else heard anything like this? Was it the throw out bearing?
If the clutch throwout (release) bearing is quiet when cold drive the car around until the engine and drive train are up to temperature. If you ever hear/feel anything from the clutch when you depress the clutch pedal or while releasing it, that's almost certainly a release bearing.
I'd not wait for the thing to get worse. I'd schedule the car in for a new clutch and of course release bearing ASAP.
If you hear any noise that is not affected by pressing in or releasing the clutch that's something else. Could be a noisy serpentine belt idler or tensioner roller bearing or an accessory drive, with the water pump being the most likely source.
I have the 99 C2 with 90k and occasionally hear a soft squeal when releasing the clutch from a complete stop but only when the drive train is completely up to operating temperature. The squeal lasts one second only. The clutch was inspected and deemed fresh enough to leave in from the PO when he had the IMS/RMS/AOS done about 5k miles ago. The PO an indie Porsche mechanic who owns ROCS in NJ. I took his word for it and bought the car. I am certain that what I am hearing is clutch related. It is not advanced enough to remove the gearbox and replace right now. The clutch bites very well. No slippage at all.
I would try getting the car up to temperature, open the door at standstill, and then try out the clutch. Mine made a horrible sound, also with the engine off. The noise is was only audible from outside the car.
This happened after installing a new clutch, fallout bearing, the works.
Have a listen
Something like this?
Have a listen
My throw out bearing started whining at about 65k miles. When i would depress the clutch it would go away. I changed the entire clutch assembly as it didnt make sense to do all that work and leave the old clutch disc in there.
I do not quite know in detail what was wrong, but there is an explanation there that you can read.
