Would a failing CPS trigger CEL?
Would a failing Crank position sensor trigger a CEL even if it was just problematic during warm start?
Started to check my earth point cables and have ordered the starter-alternator cable. This will problably solve my slow warm start.
Just want to rule out CPS, no CEL on the car which is nice.
Will maybe replace starter while I am in there
Battery is tested, perfect. Starter runs perfect at cold start, can still be failing.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
If you are seeing the CEL come on read the codes both active and any pending and post for comment.
There should be a list of 996 codes here somewhere - look through them for one related to CPs ... My Benz w204 had failing camshaft ps - which threw a code which I could clear with basic odb reader and then it would come back a few days later. Replaced magnets and all was fine ...
