Window Regulator?
I am a relatively new 996 owner (about 6 months). It is a 2000 carrera coupe. It has a TPS turbo and it is in pretty decent shape. I will try to post some pictures soon. Today I tried to replace the passenger side window regulator. I have a new regulator marked R. When I removed the old regulator it was marked L. I put it back since the new one did not seem to fit. Was that a mis-labeling, are they interchangable. I will appreciate your assistance on this matter.
Jose
Jose
They are different parts with different part numbers. It's weird that the new one didn't fit. I know that replacing one is a pain in the a**.
Left side or drivers side is 99654207504
Right side or passenger side is 99654207604
they may have givin you the wrong one. it happened to me, I specifically asked for passenger side. didn't figure it out till i had the door apart and it took a week for the right one to arrive
Thanks for your response, friends. The bottom line is that the window regulator on the right side of the car is marked L. I bought one marked R. I probably did not try to install the new one hard enough. I tried to see if there is a part number printed on the part but there is none.
I might try again , but it is a lot of work. The window is going up and down but it does not come down enough when the door handle is pulled. I suspect the regulator is a little bit stretched.
