996 Forum 1999-2005
Loud noise at startup... immediately goes away?
Old 03-20-2015 | 02:31 PM
kmagnuss's Avatar
kmagnuss
Default Loud noise at startup... immediately goes away?
My car has the exact same noise at start up after it sits awhile as the car in this video:
Is it lifters? Chain?
Fresh Mobil 1 0w-40 is in it... I'm probably going to change to 15w-50 pretty soon.
99' 6 spd 32k miles.
Thanks.
-Mag
Old 03-20-2015 | 02:44 PM
Sneaky Pete's Avatar
Sneaky Pete
Go to a thicker oil.........5-40 and dare I say try out some DT-40.......now I did it I posted a suggestion to oil use.
Old 03-20-2015 | 02:49 PM
Mark I's Avatar
Mark I
If I'm focused on the right sound, what I'm hearing may be the starter gear remaining engaged longer than it should.
Old 03-20-2015 | 02:51 PM
Ahsai's Avatar
Ahsai
You mean the noise @0:03s and the rattle @0:04s? I don't hear anything obvious after that. Checked your heat shields?
Old 03-20-2015 | 02:52 PM
Ahsai's Avatar
Ahsai
+1, I heard the same @0:03s.
Old 03-20-2015 | 04:28 PM
mcbit's Avatar
mcbit
+1 on what Mark I and Ahsai said.
Old 03-20-2015 | 05:06 PM
speed rII's Avatar
speed rII
Same car, same noise, how do I know it? It's my car.
I have had that noise about 3y now, and I think that it's coming from the DMFW.
Rebuilded my engine 60k km's ago, and after that this noise was still there.
(rod bearing broke, so that was the reason rebuild/refreshing)
Old 03-20-2015 | 07:33 PM
kmagnuss's Avatar
kmagnuss
Sorry but what is DMFW?
Thanks guys.
Old 03-20-2015 | 07:36 PM
alpine003's Avatar
alpine003
Thanks guys.
Dual Mass Flywheel
Old 03-21-2015 | 03:53 AM
Macster's Avatar
Macster
Normal.
My car engines make a similar noise when I leave then engine off a long time. The last time I heard this was from the Boxster's engine when I left it off for over 3 weeks when I was away.
If you want switch to 5w-50. This is not a typo for 15w-50!
Old 03-21-2015 | 07:25 AM
Hurdigurdiman's Avatar
Hurdigurdiman
If I am focused on the right sound. Both films they are using the acceleration pedal. A no no on start up.
Quick Reply: Loud noise at startup... immediately goes away?
