996 Forum 1999-2005
Tire pressures
Old 03-20-2015 | 01:05 PM
DTMiller's Avatar
DTMiller
Originally Posted by lagodue
I have been reading for years to check the 'cold' tire pressure. But what is 'cold' tire pressure? Somewhere it says a minimum of 3 hours after driving. In my garage in upstate NY it is 30 degrees F. right now, but at my condo in Florida it is 80 F. The 'cold' measurement will be dramatically different in each place, as will the tires' performance at the same inflation.
Can't find anywhere that sorts this out technically for me.
Check this out. http://www.tirerack.com/tires/tirete....jsp?techid=73
Should give you the info you need. Your instincts are correct, tire pressure is affected by ambient air temperature and the variation in ambient air temp.
Old 03-20-2015 | 01:19 PM
lagodue's Avatar
lagodue
Thx - good link!
I see where their test says: "We monitored the changes in tire pressure in 5-minute intervals. "
Not sure how they do this, but it seems every time I put the gauge on the valve 1/2 pound leaks out! https://rennlist.com/forums/images/smilies/frown.gif
Old 03-20-2015 | 02:11 PM
DTMiller's Avatar
DTMiller
Thx - good link!
Their test rig probably has a built-in tire pressure monitor that checks pressure without adding/reducing any air in the tire. Just my guess, though.
Old 03-20-2015 | 03:17 PM
Ahsai's Avatar
Ahsai
BTW, I highly recommend this digital gauge
Amazon.com: Accutire MS-4350B Setpoint Tire Gauge: Automotive Amazon.com: Accutire MS-4350B Setpoint Tire Gauge: Automotive
It waits for pressure to stabilize before taking the reading and will beep when the reading is ready. You get consistent reading all the time and don't lose 1/2 pound when you put it on.
Quick Reply: Tire pressures
