996 Forum 1999-2005
Epoxy for my new garage
Old 03-24-2015 | 10:54 PM
thebowl's Avatar
thebowl
Also check All Garage Floors, which has a lot of good stuff.
I did my floor last year. I used Sherwin Williams commercial products. I should have spent a bit more time on prep (my floor was 20+ years old), but I got a nice outcome, all things considered. I used an epoxy (two part) with color chips, and then a clear coat over that. I probably didn't even need the clear coat.
Amen to using some non-skid product, depending on what top coat you use. Very important.
Old 03-25-2015 | 12:11 AM
bal's Avatar
bal
Looks like WeatherTech is getting into the plastic floor tiles game. http://www.techfloor.com
Old 03-25-2015 | 01:01 AM
Mark I's Avatar
Mark I
Originally Posted by rwiii
On the porcelain tiles wouldn't oil and other fluid stain the grout? It looks awesome.
Two ways to avoid that - stain resistant grout or there is an stain blocker additive that is used in place of water when it's mixed.
Old 03-25-2015 | 03:21 PM
Tim Wasmer's Avatar
Tim Wasmer
I have done several things to floors in places I have lived. I used the epoxy and was not impressed with it price vs. longevity.
I also did one garage in VCT tile (like in the grocery store) and it was the best thing I have used so far.
I also have used this oil based paint and it has held up very well AND it was less than $20 a gallon at Lowes. This is what is in my current garage. I want to do VCT tile but have not had the time.
You can kind of see the flooring with my PCar parked on its carpet
Link to paint: http://www.lowes.com/pd_46516-4-057....3343608&rpp=32
Old 03-25-2015 | 04:45 PM
alpine003's Avatar
alpine003
I can vouch for this and have also done this and would be my first choice. However in my experience, it only works really good if your floors/concrete is even and you use a waterproof adhesive. Unfortunately, my current place has 50 year old cracked uneven concrete.
At $.50/sq ft, it is very economical too. It comes in so many colors now too compared to awhile ago when you only had a few color choices.
I'll have to give the Lowes a try on my basement shop floor as it needs to be touched up. Thanks Tim for the suggestion.
Old 03-25-2015 | 04:55 PM
Tim Wasmer's Avatar
Tim Wasmer
It is an oil based paint so takes a bit more time to cure but has been tough.
Agreed, I had to fill in the seams and thankfully my floor was newer and flat.
Old 03-25-2015 | 05:15 PM
Porscheby40's Avatar
Porscheby40
My first garage had B&W VCT tiles. Cheap and easy to install, but slick when wet.
My second garage had B&W RaceDeck.
My third garage will have 12" x 24" light gray Italian porcelain tile soon.
Old 03-26-2015 | 12:40 AM
Gulliver's Avatar
Gulliver
In my experience, it's been hot tires that want to lift most coatings. Even just a few minutes outside the door before pulling in will help, a good time for a post drive wash.
Old 03-26-2015 | 12:54 AM
alpine003's Avatar
alpine003
Unless you just pulled in from the track, tires don't get that hot IMO.
What I find lifts epoxy floors are either poor prep(poor degreasing, no acid etch, primer,etc) or owners that do not do a proper moisture test on their concrete before deciding to coat it.
Old 03-26-2015 | 01:06 AM
bal's Avatar
bal
Between the VCT and the RaceDeck, which did you prefer?
Old 03-26-2015 | 03:30 PM
Tim Wasmer's Avatar
Tim Wasmer
I also park my cars on outdoor carpeting for easy clean up of winter garbage. Pull them out and power wash them, dry, pull back in
Old 03-26-2015 | 06:08 PM
alpine003's Avatar
alpine003
I do something similiar but park on ribbed parking mat to capture some of the winter mess. This is also done to hide some of the concrete cracks I had mentioned previously.
As for the VCT vs Racedeck, be aware if you have Racedeck and not 100% level floors, you might experience some clacking noises as you step on them. Cleaning the underside from time to time can also be a chore but the plus side is you can always remove them and/or take them with you if you ever move.
Old 03-27-2015 | 03:11 AM
uswrnk54's Avatar
uswrnk54
Used this when we moved in nearly 6 years ago. Not a blemish yet, looks great.
http://www.homedepot.com/p/Rust-Oleu...1870/100671422
Old 03-27-2015 | 03:24 AM
Porscheby40
I liked Racedeck better - it wasn't as slippery, had better color choices and was easier to install. The only downside, other than the expense, was a slight clacking sound when walking on it.
Old 05-18-2015 | 05:00 AM
Willo's Avatar
Willo
Default Reply
Hi guys, next week I'm going to giving my garage a new look as I have hired the floor contractors to install epoxy floor coating from Toronto with Chessboard design that would look even more stylish with my BMW 750Li. I would surely post the pics when the work is completed. Very much excited.
Quick Reply: Epoxy for my new garage
