IPD Plenum
Hi All,
Anyone have experience with the IPD Plenums?
http://ipdplenums.com/products/plenums/carreras/996-carrera
My application would be an '01 C2 tiptronic. I guess the second one up from the bottom, going for $795. Is it worth it?
Let me know what you think, I appreciate any and all feedback.
Thanks guys
Thanks guys
I don't think it's going to be worth it alone. Unless you can buy one used just to try it out but to me $800 is a lot for one part...
I personally have the headers, IPD plenum and an EVOMS intake. Got all the parts for less than $900. Car already had the Gemballa mufflers when I bought it. It sounds better and has more power in the midrange. Going to do the FVD ECU upgrade as well to see what that does. That will be it for me.
1 Post
I am thinking about the competition one (comes with larger tb and plenum). I can see that working, a lot more air flow, I think it is $1,000 or so. Going to to my cat bypass pipes first (hopefully installing soon) then decide if I want headers, bigger brakes, ecu tune or the new intake (maybe new intake manifold as well, larger gt3 side or something...if it fits a 3.4l). I'm just scared I'll get a bigger itch and go do a single turbo conversion (no superchargers for me)
My CTT has a IPD plenum, along with all the other bolt on's available (CAI, highflow cats, secondary cat delete, injectors, larger turbos, ecu tune, etc). I would say the plenum didn't do anything! However the stock plastic one was cracked, so it's worth the few extra bucks at that point.
I do not have headers on the car.
Right now I only have the K&N FIPK intake, and agency power exhaust. To the best of your knowledge do you think the IDP plenum would do any justice with my current setup? Or would it just be $800 down the drain.
Thanks for that,
IPD wouldn't be my first mod but more like my last mod.
I have headers, cat bypass, evoms, ipd, tb and custom ecu will be next.
As for GT3 IPD on a 3.4 or 3.6 with stock cams and no headwork would be a waste. You can get a $50 manometer and test it out yourself. Or just log the MAF value if you're only testing the enlarged GT3 TB/IPD combo and see what you get back.
