996 Forum 1999-2005
New Engine Clatter that rises with revs
Old Feb 26, 2015 | 01:46 PM
Track1st's Avatar
Track1st
Former Vendor
Originally Posted by Spinout
This may sound out of left field but it happened to me. I had pulled over and heard a loud rattle coming from the bottom end of my car. The death rattle. It increased w/revs but all vital signs were good (oil pressure, vacuum, oil color, coolant color). I had the car flatbedded to my tech expecting the worse.
I got a call from my tech a few hours later hoping for the best but expecting the worst. It was...
...a bad catalytic converter. Whew. It was very hard to discern where the noise was coming from being the cat is right in front of the oil pan. Even my tech who is a seasoned 996 specialist had to drill a hole in the cat and stick a rod inside to put pressure on the element (the rattle then stopped) to confirm it was indeed the cat and not a lower end rod bearing or similar.
Here's to hoping it's a simple, cheap remedy....
Thanks so much for the glean of hope!
Old Feb 26, 2015 | 02:08 PM
Track1st's Avatar
Track1st
Former Vendor
Originally Posted by alpine003
Just curious what your rationale was to drive it for 10 miles with the clatter? I'm hoping you didn't damage the engine more by driving it. Also just doing a visual on the oil isn't good enough. I would send a sample to Blackstone or other analysis place.
On my way to a meeting. Did not notice rattle until exiting freeway. Nowhere to easily stop. All other factors looked healthy. No vibration. No smoke. Good gauge reading. Running well. So I completed the last mile or two of the journey and flat-bedded it out of the car park at the office. To be honest it did not sound or feel fatal at the time.
Old Feb 26, 2015 | 02:10 PM
Track1st's Avatar
Track1st
Former Vendor
I'm enjoying your ray of hope.
Old Feb 27, 2015 | 11:02 AM
Track1st's Avatar
Track1st
Former Vendor
Thanks for everybody's kind thoughts and comments.
I got some good news. We drained the oil and removed the engine pan (really a bottom plate). No sign whatever of problems. Plate was clean and clear. The visible moving parts looked really good. Nothing to worry about.
Today the oil and filter will be replaced and the engine started with stethoscope in hand. Wish me luck.
Hope its the broken catalytic converter problem suffered by Spinout.
Old Feb 27, 2015 | 12:53 PM
Barn996's Avatar
Barn996
So far so good,fingers crossed for a positive result.
Old Feb 27, 2015 | 04:10 PM
Track1st's Avatar
Track1st
Former Vendor
Feeling much much better now. Wondering just what was the fuss.
Stethoscope confirms no noises from engine and it is likely a noisy serpentine pulley. Much relief, smiling. Should get car back early next week.
Thanks everybody.
Old Feb 27, 2015 | 04:29 PM
kalyan's Avatar
kalyan
Woot!!
Old Feb 27, 2015 | 04:50 PM
nkgosselin's Avatar
nkgosselin
Great outcome.
Old Feb 27, 2015 | 07:25 PM
alpine003's Avatar
alpine003
Originally Posted by kalyan
Woot!!
+996. But I would still do an oil analysis.
Old Feb 28, 2015 | 08:04 AM
Track1st's Avatar
Track1st
Former Vendor
Originally Posted by Gretch
Water pump.
And the prize goes to Gretch. Water pump it is.
Old Feb 28, 2015 | 10:54 AM
Sneaky Pete's Avatar
Sneaky Pete
Originally Posted by Track1st
Water pump it is.
NICE! Glad this turned out well.
Old Feb 28, 2015 | 12:58 PM
Track1st's Avatar
Track1st
Former Vendor
I guess anything less than major engine failure counts as good news! Thanks
Old Mar 1, 2015 | 04:58 PM
ChicagoSpeed996's Avatar
ChicagoSpeed996
Glad it turned out well!!!
Old Mar 21, 2015 | 12:10 PM
Track1st's Avatar
Track1st
Former Vendor
Default A Final Wrap-up
So the pump and thermostat were the originals. They survived 14 years and 58,000 miles. Par for the course I guess!
Old Mar 22, 2015 | 11:51 PM
Schnell Gelb's Avatar
Schnell Gelb
Because of the age , a "while you are in there" list may be useful ?
1 Belt.
2.The two idler and the tensioner pulley bearings may be getting noisy? You can in theory replace just the bearings if you have the equipment.Probably need a 10t press.Be careful using a 20t -easy to split/bend/distort the steel pulley. I upgraded to n.o.s. SKF bearings "Made in USA". Timken is =.
Soak the bearing+pulley in penetrating fluid overnight before using a press to push the old bearings out. Clean off all p/fluid from pulley. Freezer overnight for the new bearings.Use a smear of blue Loctite or green as a 'lubricant' to help the new bearing slide in without distorting the pulley. I paid about the same for a premium quality SKF bearing as for an OEM pulley with a generic bearing. If you are concerned about the quality of the bearing ,be careful to avoid Indian ,Chinese and other unreliable sources -even if they claim it is "SKF".Just my 2c.
