996 Forum 1999-2005
New 996 Owner. 1st Porsche.
Old 07-12-2016, 02:02 PM
  #256
Slakker
Slakker's Avatar
Great driving. I thought you were going to get a point by from him for a minute!...I love the lens on the camera. Now if you just had Harry's to add a little telemetry.....
Old 07-12-2016, 02:40 PM
  #257
vandersmith
vandersmith's Avatar
Still need to figure this one out as I really like this angle versus the multiple GoPro setup I used to run.
I've paid for Harry's but have been using an AimSolo DL for the past few years for on track use as it captures a ton of data - I'm pretty pot committed
The only problem I have with it is trying to get the Gauge overlays to work and calibrating it. Haven't quite gotten the hang of it
Old 07-12-2016, 06:47 PM
  #258
Noz1974
Noz1974's Avatar
Do you have any more info on the 2nd gear detent, my 2nd gear a bit notchy when box is cold??
Thanks!!
Old 07-13-2016, 05:17 AM
  #259
vandersmith
Thanks!!
Its hard for me to say.
Between all of the new parts I'm actually not sure how much its helped. I don't have comparison photos otherwise I'd share them but from the shop they said it was a pretty simple install.
My car also shifted hard when cold, seems normal but I guess I can tell you that I haven't had a single (NOT ONE) 2nd gear pop out since. I've grinded from 2nd to 3rd at the track under load due to poor clutch action on my part - been trying to commit to the one heartbeat shifts but its tough.
If you're doing some work in that area I'd say go for it. Call up the guys at GBox in CO - they're super helpful
Old 07-14-2016, 04:09 AM
  #260
vandersmith
Spent a few hours cleaning the car up trying to get all of the track grime off.
Finally invested in a gas pressure washer and tried my hand at the foam cannon with two bucket wash.
No wax or clay bar this round, just a quick rinse.
Old 07-14-2016, 10:20 AM
  #261
Slakker
Slakker's Avatar
Looks great. I think I like it better without the yellow headlights.
Old 07-14-2016, 11:49 AM
  #262
alpine003
alpine003's Avatar
Do you DD that car too? Damn, I can't see getting in or out of any businesses around me with that height without scraping or taking out the front bumper.
Old 07-17-2016, 02:07 PM
  #263
vandersmith
Chasing a 2015 Audi R8 V10 and 2016 Porsche GT3RS:
Old 07-17-2016, 03:06 PM
  #264
crmcgregor
crmcgregor's Avatar
[QUOTE=vandersmith;13457630]Chasing a 2015 Audi R8 V10 and 2016 Porsche GT3RS:
Looks like a lot of fun, what was used to record in 3D? That was neat...
Old 07-18-2016, 01:27 PM
  #265
slidefighter
2nd Gear
slidefighter's Avatar
What a terrific thread, I've really enjoyed it. If I may be so bold as to ask the definition of a few acronyms... I'm completely new to both Porsche and the 996. Bought a 2001 C4 this weekend and don't even have it yet. You guys seem to talk in a kind of language all your own! Can I get some translations:
1. AOS
2. PDC
3. DD
4. DE
5. 997TT
6. plenum/TB
7. HRE 540/MSS
I read the whole thread and figured out a 50 others I haven't listed, but I haven't broken the code on these seven yet.
Thanks!
Lee...
Old 07-18-2016, 01:31 PM
  #266
vandersmith
Originally Posted by slidefighter
1. AOS - Air Oil Seperator (mainenance part)
2. PDC - Porsche Dynamic Control
3. DD - Daily Driver (Is this your main car?)
4. DE - Driver's Education (Track Day)
5. 997TT - 2004-2012 911 Turbo
6. plenum/TB - Intake component behind throttle body before heads
7. HRE 540/MSS - HRE wheels Type 540 with Michelin Pilot Super Sport Tires or (MPS2/PSS/etc.)
Congrats on the new car!
See in lines above
Old 07-18-2016, 02:32 PM
  #267
slidefighter
2nd Gear
Colin: Thanks for the quick response; some obvious and some not so much! This car is not planned as a daily driver, I've got an older BMW 3-series for that, but I plan to drive it a lot. Will split duties with my 2002 Maserati Coupe and whatever comes next as an alternate day driver! Not really a car guy, but I woke up the other day and realized I'd never had a Porsche, so...now (or at least soon) I'll have one and a lot more to learn.
Lee...
Old 07-18-2016, 08:34 PM
  #268
vandersmith
Went to a BMWCCA Dyno day this weekend with some interesting results.
They had a AWD dyno but I didn't realize I needed to remove the drive shaft in order to get accurate readings due to the front differential...I'm an idiot.
The results were off: 270awhp/200torque
I didn't find any intake or exhaust leaks, the oil was fresh, the ignition system has been overhauled and compression is fine. Turns out the Pcar AWD system isn't like typical Audi/BMW/Subaru setups and I didn't realize that made running on the dyno much more complicated.
The front differential is all mechanical/fluid (viscous clutch) and transfers from the normal 5% of power to anywhere up to 40% when any wheel slippage front or rear is detected by the wheel sensors. Its not a standard 50/50 which I knew but didn't realize it made this process that different.
To counter this parasitic loss, when the Twin Turbo cars (AWD too) dyno they remove the drive shaft to the front wheels (converting to RWD) to get a more accurate reading. This has zero impact on the rest of the car as there are no electronics involved in the front diff and PSM only applies to braking.
In my case, by running on the dyno in AWD the car believes the fronts are slipping as they are spinning at a slower speed than the rears. If the dyno isn't setup to lock both rollers so they are at equal speed, (which it wasn't in this case) this can actually damage the driveshaft and differentials by boiling the fluid as it tries to keep up and transfer power constantly to where it senses it needs it.
Long story short: Time to pop off the crankshaft and see what it does next time.
Old 07-22-2016, 04:32 AM
  #269
vandersmith
No more weird clutch spring thing!
No more AWD!
Old 07-22-2016, 04:40 AM
  #270
Slakker
Slakker's Avatar
Sweet! Can't wait to hear your feedback on the differences and how it feels.
Now that you have it nearly perfect are you sure you don't want to sell it and start over with a 996 C2S? Lol, idiots.
Quick Reply: New 996 Owner. 1st Porsche.
