Are you a gambler? Would you buy it?
I believe the bigger bearings have proved to have a less than a 1% failure rate, which is why they were excluded from the IMS settlement. I suspect there is no way to tell which bearing you have without dropping the engine or transmission.
If it has the smaller bearing, concur with swapping it out with the LNE bearing.
I put no stock in the cursed car theory. It's a machine, not a mentally disturbed woman. What are we, freaking gypsies or something?
Yes based on what I'm hearing I would run far fast and far. There are so many no story cars out there for cheap. This one would have to be under $15k for me to even think about thinking about it.
the money and mileage is appealing for a reason
the car has been taken apart twice, engine / transmission taken out
stuff gets missed
what is Manhattan Motors reputation for rebuilding motors ?
stuff gets missed
I only see one major problem with a rebuild at the dealer. Where did they get the specs to rebuild it to? I thought Porsche never published clearances or tolerances for anything in this engine. How would they know of the crank was good? How would they know if the rod bearing clearances were good? How could they possibly pull off a decent rebuild without the specs to do so. They were guessing... I would guess this car hasn't seen its last engine.
To the OP, it wouldn't concern me. If it's a good running and driving car with a clean bill of health, I would definitely buy it. That's a good price for a C4S.
Huh? You really think a dealership would rebuild an engine and warranty their work based on guesswork? A dealership has access to more Porsche engine data than any independent. Dealerships also very rarely venture outside of what Porsche recommends, and in the case of M96 rebuilds they almost always replace, not rebuild. So I suspect any parts that needed replacement were actually replaced.
I have NEVER heard of dealerships having access to engine rebuild specs which is exactly why almost none were "rebuilt" at dealerships. Can you verify that this dealer actually had the specs from Porsche in order to effect a quality rebuild?
The onus is on Porsche, not the dealer. The dealer did what Porsche recommended, even if it was beyond the scope of the shops abilities.
I suspect that if dealer techs had access to rebuild specs for these engines they would have leaked to the public a decade ago. The ONLY specs I have heard of are the ones Raby developed based on experience.
I too would run, not walk from this project car.
Stay away. Cursed cars are like jinx people, you stay the **** away!
An RMS is not an engine. An RMS is a cheap seal that tends to leak. An RMS is not a big deal. That car is on engine #2.
02APR2003 - 2,459 miles, engine replaced (Engine #2 goes in)
03MAY2006 - 22,961 miles, RMS fixed
25AUG2009 - 34,167 miles, engine rebuilt due to IMS failure. (Engine #3 goes in)
If the third engine was replaced instead of rebuilt I would have no qualms. The way to differentiate the two is to use the engine serial number. It will look like m96/03SAT665 where the AT means rebuild and the 5 means rebuilt in 2005. If it is engine #2 the last digit will be either 2 or 3, if engine #3 is a factory rebuild it will be 9. There is nothing wrong with buying an old car with a fresh engine unless you are paying for a numbers matching hemi.
To read the engine number take a picture of it with a phone. It can be done without jacking the car up.
I'm with the naysayers, Josh. Too much kale for a pig in a poke. Lots of fish in the sea. Tuck your insurance cash away and look patiently for your next car.
What? I will attribute your lack of mathematical aptitude to a long 3 day weekend hangover.
I'm fluent in four languages you know.
Four?! You speak French, Spanish and German.
I do pretty good in English as well.
Oh, yeah.
I'm not sure what kale, pigs, sugar and dimes have to do with anything...
But,,,,,,
The temptation is so strong....
Like I said, I am still learning about the car so it is great that I am getting feedback from both sides on what I may be in for.
As an Engineering Automotive Technology major here at Minnesota State, we are encouraged to work on our own cars. I figured, what better way to fill my love of Porsche while at the same time, progressing my knowledge of Automotive Systems?
I have a lot to consider, I will keep you all informed as I go.
Again, thank you for the feed back, it is worthwhile.
Regards,
DC Josh
But,,,,,,
Regards,
DC Josh
