Help-Dealer wants $1200 to fix tire pressure monitor!
I am am emailing on behalf of my dad who has a 2007 911. The battery died and he went through the normal procedure to get the car going again. Once the battery was recharged he noticed that the tire pressure monitoring system was no longer working. He assumed that the system would reset itself after driving for a while and it did not.
He took the car to 2 dealers and they each said it would cost $1200 to fix the problem…they said that the batteries for the tire pressure system needed replacing. He has never heard of this and neither have I.
$1200?? Really!
$1200?? Really!
Some of the TPMS sensors are disposable - when the batteries are kaput, you install new sensors. $300 per wheel sounds about right for Porsche.
Link to another site with discussion:
http://www.6speedonline.com/forums/9...ative-opc.html
My battery died and I went through the normal procedure to get the car going again. Once the battery was recharged I noticed that the tire pressure monitoring system was no longer working. I assumed that the system would reset itself after driving for a while and it did not.
I took the car to 2 dealers and they each said it would cost $1200 to fix the problem…they said that the batteries for the tire pressure system needed replacing. I have never heard of this.
$1200?? Really!
$1200?? Really!
do a search and you'll find plenty of answers. If you don't find it on the 996 forum, you can for sure on the 997 forum.
Mike
Super Moderator
I just bought 4 new TPMS sensors for my BMW, same brand that BMW uses for $240.
My local tire place put them in my winter wheels/Tires no problem, for $125.
Get away from the Stealership.
Porsche TPMS probably the same
Having moved to a 2006 (turbo S Cayenne) I can testify that there is a $160 solution.
I bought new sensors ($160 for 4) and had them fitted when my snow tires were mounted.
The original (ca.2006) units had given up the ghost.
Discount Tires did the dirty work, the OBC learned their position within 10 miles.
Your 911 may need a learning cycle (otherwise known as a 20 minute/mile drive).
Rocky Mountain High
That price is correct for OE parts from the dealer.
You should be able to have aftermarket sensors installed in your dad's 997 by an independent tire shop for roughly half of that amount.
$1200?? Really!
$1200?? Really!
But too often the owner is back not long after with one or more dead batteries in his car's TPMS sensors. Often times the owner wants to blame the tire mounted operation for damaging the sensors, but this is not what happens.
It just so happens the TPMS sensor batteries ran out of time. The SM has seen this time and time again which is why he (and the techs if you ask them) will recommend new sensors/batteries when the tires are changed.
Now if the sensors have been replaced in the past, or even if they are original, you owe it to your dear Dad to read through the owners manual and see what needs to be done after the battery has been replaced. I assume the battery died and was replaced. If not I need to know what was done to resurrect the battery? They really do not take kindly to begin run flat and while they might take a recharge and appear to be ok they often are not. It is just best to replace the battery and make a note to never ever let one run flat.
It could be the temporary loss of battery power has rendered the TPMS controller and its receiving antenna inoperable and with some procedure using the car's OBC stalk you can resurrect the TPMS controller.
Some Porsche models have a learning procedure for the TPMS, check the manual. There's no reason why a dead battery would impact the TPMS sensors.
As for the cost, my dealership will charge $250 to replace your air filter. So there you go......
