996 Forum 1999-2005
Battery Drain
Old Jan 4, 2015 | 02:35 AM
  #61
Stephen Tinker's Avatar
Stephen Tinker
Originally Posted by targa996
Thanks for the link to pulling the alternator - I got to the part when I hammer the bushing in - could not make it budge. Soaked in P Blaster - drift punched on the bolt, then directly on the bushing - it is not moving - thx
Targa - I hope this is not a silly question, but how much did you loosen the offending bolt before you hit it with your punch?
When I changed mine, I loosened the bolt about 4-5 turns before giving the bolt head a good smack. Only then will you feel the bolt is loose and be able to move the alternator around.....
Old Jan 4, 2015 | 03:35 PM
  #62
targa996's Avatar
targa996
Took the bolt right out - removed the pulley - then screwed it back in - most of the way .....
Old Jan 18, 2015 | 08:55 PM
  #63
targa996's Avatar
targa996
Default Alternator Out !
I read somewhere brass bushing is heat fitted - so after hammering to no avail on the bolt - I went to harbor freight and got a butane pencil torch
http://www.harborfreight.com/butane-...rch-41169.html
zip tied oil filler tube out of the way - and then put aluminum kitchen foil around the tube and behind alternator rear bracket - just in case. Lit torch - held for 30 seconds or so on aluminum casing around bushing - tapped with 3 pound drift hammer on pulley backed out 3 turns - using 2' (x0.5") aluminum rod I got at home depot (tool rental center cut 3' rod into 1' and 2' length for me) - using towel to protect rear bumper. Bushing moved like hot knife into butter ! Then alternator started swinging out immediately - still a bit fiddly to clear both brackets that hold the alternator bolts to engine - but after 5 mins or so of wiggling - got it out.
Pressed on lock for connector plug and this pulled off easy. Nut holding +ve cable was on a bit tight - used PB blaster and long handle wrench on 13mm socket to get it loose.
Now off to local alternator rebuild shop.
I think with the torch trick - I would have had this thing out in less than an hour (instead of 3 x 1 hour attempts). So hopefully these tips will save someone else some time. Still better than the $1K or so quoted by the shop. And really not hard - after you know how to deal with the bushing. OK time for a beer.
From the picture you can also see the reason for all these problems - Bosch Alternator is "made in Great Britain" Did they buy Lucas or someone ?
File Type: jpg
Old Aug 28, 2016 | 07:48 PM
  #64
Ahsai's Avatar
Ahsai
I know it has been a while. Did the new alternator fix the battery dain problem?
Old Aug 28, 2016 | 09:39 PM
  #65
targa996's Avatar
targa996
yep - perfect now - the clue the alternator diodes were going bad ...was the alternator body was warm after letting it sit overnight
Old Aug 28, 2016 | 09:52 PM
  #66
Ahsai's Avatar
Ahsai
Thanks for the info...was just curious what happened.
