996 Forum 1999-2005
996 Warranty
Old 12-10-2014, 08:26 PM
kab1994
kab1994's Avatar
Default 996 Warranty
I just purchased a 2003 996 Mk2 w/ 42,000 miles. I am looking to purchase an aftermarket warranty for the car. I have a quote from Direct buy warranty and Easy care. Fidelity will not warranty the car. Has anyone had experience with either of those companies, or can you recommend a warranty you currently have? My main concern is an IMS failure.
Old 12-10-2014, 08:46 PM
prosled8
prosled8's Avatar
ISMB retrofit will probably cost less than the warranty, and last longer. Heck you could probably do the IMS solution for the $4000 the warranty would cost.
Old 12-10-2014, 09:05 PM
kab1994
kab1994's Avatar
I understand that the IMS upgrade is roughly $2200 for my car, but I would rather spend $4000 on a big fat warranty on my car that will cover everything. If the IMS fails then that gets taken care of plus I still have the rest of my car covered.
Old 12-10-2014, 09:54 PM
pfbz
pfbz's Avatar
Received 2,744 Likes on 1,473 Posts
Beware of aftermarket warranties... They rarely cover as much as you think, and it's usually a fight to get anything.
Most aftermarket warranties have language similar to what's shown below for engine coverage, and deny coverage for IMS-related damage because it is not an internally oil lubricated part. Either way, you are far better off preventing an engine problem for $1,500 or less than fighting an insurance claim for a $15k-$20K repair.
By the way, the underlying basis of the Porsche IMS lawsuit was similar, but with Porsche extended warranty... The named plantiffs had certified pre-owned (CPO) warranty cars with IMS failures and Porsche denied CPO warranty coverage to them.
Covered Components -
Engine - All internal components of the engine that require oil lubrication for operation....
Old 12-10-2014, 10:43 PM
rpm's S2
rpm's S2's Avatar
Be sure any warranty has a detailed seals and gaskets rider. Without this coverage the warranty will be useless.
Old 12-10-2014, 11:37 PM
kromdom
kromdom's Avatar
Contact your local, trusted Porsche indy and ask what warranty company they had a positive experience with. Then contact that company and ask if they will cover IMSB failure and ask for that reply in writing. Buy that warranty that says YES in writing.
Old 12-11-2014, 12:08 AM
Rubik
Rubik's Avatar
After market warranty is BS. I have mine and I will cancel next week. They don't cover ****! It's a ****ing scam.
Old 12-11-2014, 12:36 AM
Gonzo911
Rat Balls
Gonzo911's Avatar
In addition, there is usually language that they will not make any repair that exceeds the value of the car. I won't go any further.
Old 12-11-2014, 01:07 AM
kab1994
kab1994's Avatar
Are you saying that the IMSB is not an internal lubricated part?
Old 12-11-2014, 01:42 AM
Ahsai
Ahsai's Avatar
The stock IMS is sealed and lubricated by grease and not engine oil. Aftermarket open bearings such as LN is splash lubricated by engine oil.
However, whether the bearing REQUIRES engine oil lubrication is arguable...maybe it does but just doesn't get it by design...
Old 12-11-2014, 02:08 AM
johnireland
johnireland's Avatar
I have an Easy Care policy that I bought through a Porsche Dealer. Easy Care has been in business since the mid eighties. I didn't get the whole works, the one step up from base warranty, which covers the engine, trans, and fuel system. I paid $2500 for 3 years or 36000 miles. Based on the numbers in the class action suit against Porsche, the failure rate for IMS shaft/bearing/cam chain gear or what ever failued...is 2%...or roughly 3500 failures out of 235,000 cars. As noted in this thread, a $2500 drive train warranty covers a lot more than just one bearing.
Old 12-11-2014, 10:49 AM
alpine003
alpine003's Avatar
The only sure thing that is covered by a lot of these warranty companies is the lube they use for your ****.
Old 12-11-2014, 10:59 AM
prosled8
prosled8's Avatar
Consider that if you desire a car with a good warranty, maybe a 10-15 year old sports car is not the right choice. Fact is, there isn't much else that goes wrong, you don't really need a big fat warranty. The more you read here, the more you realize that the problems are greatly overstated. Failures are quite rare. Look at the IMSB as a maintenance item at clutch time and the car will last a long time.
Old 12-11-2014, 12:59 PM
KrazyK
KrazyK's Avatar
That covers it. Even Jake says their a waste of money.
Old 12-11-2014, 03:06 PM
kab1994
kab1994's Avatar
I agree with what you're saying and I am going to do the upgrade no matter what. It's a shame the seller put in a clutch 3,000 miles ago an didn't touch the bearing, but there is no point in crying over spilled milk. I disagree, however, with your point that because I would like an aftermarket warranty I shouldn't be purchasing a 10 year old pristine car!? After market warranties are common.
Quick Reply: 996 Warranty
