996 Forum 1999-2005
Squeaky window
Old 12-08-2014 | 11:43 PM
tdrimer's Avatar
tdrimer
Default Squeaky window
When opening and closing door...window drops its normal 1/4 to 1/2 inch (or whatever it is). Problem is it squeaks in both directions when rubbing the window seal. Is there anything I can put on that rubber seal that won't ruin it to make the noise stop?
Old 12-09-2014 | 12:45 AM
johnireland's Avatar
johnireland
Does it make any noise when you raise and lower the window using the button?
Old 12-09-2014 | 01:42 AM
fpb111's Avatar
fpb111
http://www.pelicanparts.com/catalog/...inszt_pg10.htm
Old 12-09-2014 | 02:50 AM
Spokayman's Avatar
Spokayman
+1 Gummi Pflege.
Good stuff to use.
It keeps convertible top seals and other such things from squeaking too.
Old 12-09-2014 | 03:49 AM
sjg1138's Avatar
sjg1138
Mine still squeaks. Even after using Gummi Pflege.
Old 12-09-2014 | 04:45 AM
Spokayman's Avatar
Spokayman
Actually mine does too, but not from the seals that I treated. After treating the seals some of the total noise did go away which I believe means the remaining squeaks are not seal related.
I think that much of the noise is coming from interior trim pieces moving between themselves and at their attachment points.
Addressing these things is more involved than I want to get with the car and so I just let it make the noise it's gonna make.
Old 12-09-2014 | 09:08 AM
tdrimer's Avatar
tdrimer
Thanks everyone...
Old 12-09-2014 | 04:51 PM
fpb111's Avatar
fpb111
For those that still squeak. Did you lube the "rubbing" blocks ~above/behind your head? You can see them when you stop the top in the service position. Mine were so loud at certain temps that I almost couldn't hear my FisterDs.
TSB 1a/00 6101 PDF Noises in the Convertible Top Oct 27, 2000
Other TSBs for noises in the Cab top
1b/00 6101 PDF Noises in the Convertible Top Aug 24, 2001
1/00 6101 PDF Noises In The Convertible Top Sep 15, 2000
Old 12-09-2014 | 05:30 PM
JMLavoie's Avatar
JMLavoie
Great to know, Frank! Thank you!
Old 12-09-2014 | 08:48 PM
Spokayman's Avatar
Spokayman
OK, so you got me wondering and I just had to go out and look at those seals/blocks.
I just applied Pflege to all of the seals again including all I could find on the top. Takes about 10-15 minutes if you're thorough.
I just wish it were as easy to address noises in the dash trim, door panels, etc.
Thanks for the info btw.
Old 12-10-2014 | 12:04 PM
sjg1138's Avatar
sjg1138
I lubbed the rubbing blocks. I have also gone through the many Porsche TSBs on fixing noises in the Cab top and implemented many of them. I still get noises. The roads here are amazingly bad which may account for the racket. I swear there are more metal plates than pavement.
Quick Reply: Squeaky window
