Tire size
Registered User
Tire size
Another tire size question:
The recommended tire size for the rear of a 2001 C4 is 265/35 ZR18. The recommended size for a 2002 C4 is 285/30 ZR18. The 285/30 specs say it is 0.5 inches smaller in OD and 0.7 inches wider section.
My question is: with the same wheels, can I fit the 285/30 without any clearance problem?
Thanks,
Lang
Thanks,
Lang
Your car is 4wd, I would be concerned with the front and rear tires being different diameters. If the rear tires are .5 shorter then it will cover slightly less ground in one revolution than the tire that is .5 larger. I dont know if .5 is enough of a difference to upset the 4wd or not.
Thanks,
Lang
Thanks,
Lang
You should check what your wheel size and offset is. Depending on the offset, they might rub the inside of your fender wells with 295's, but that is easily remedied with spacers. Once you know what your wheel size and offset are, you can go from there and figure out if you need spacers and what size.
Registered User
My wheels are 18x 10 with 65mm offset in the rear. My question was the clearance of the 285/30s on a 2001 c4 since the factory size recommendation is the same for the front for both (225/40). The recommended wheel size is the same for both also (18x10 w/65mm OS).
Rocky Mountain High
The recommendation for the AWD system is that you keep the wheel/tire construct diameter for the fronts and rears close to the same size. I believe the "acceptable" variance is 3% or less. If you go beyond that, then there could be damage to the viscous coupling in the AWD system with long-term use.
If you use the standard front size of 225/40 R18, then your overall diameter for your front wheel/tire construct is 637.2mm as mentioned above. The 285/30 R18 wheel/tire construct has an overall diameter of 628.2, for a difference of 9mm. This represents a difference of only 1.4%, which is within the recommended variance. Your bigger issue will be the potential for rubbing, as mentioned above and as mentioned in the Porsche TSB. The TSB provides the dealer or mechanic with the steps to allow for this tire combination to be used without rubbing.
I too was concerned about having to roll my rear fenders when I bought my Sport Techno wheels (I have a 2001 NB). It think it depends on which wheels you have.
Use this tool to compare your 18x10 65mm offset wheels to my 18x11 63mm offset wheels.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
