996 Forum 1999-2005
DIY failure - flatbed
Old Sep 15, 2014 | 02:27 PM
KrazyK's Avatar
KrazyK
Unlikely as coolant pipes are quite far from the side jacking points
OK, thought I remembered one close to the passenger side. Must have been an AC line.
Old Sep 15, 2014 | 05:01 PM
AA717driver's Avatar
AA717driver
Originally Posted by KrazyK
If your stating the car was fine until you jacked it up, you need to check something. I assume you mean you were jacking it up from the side at the front jack points. Did you crush a coolant pipe with the jack. Look under the car and it will be obvious. I just dont see how it would suddenly overheat as a coincidence.
Any leaks before this? Was it overheating, then dumping coolant? Maybe crushed pipe caused overheat then boil over?
Of course it wasn't a coincidence. He messed with a perfectly good, fully operational vehicle with no apparent problems.
Let this be a lesson to us all.
TC
Old Sep 15, 2014 | 08:48 PM
PelicanParts.com's Avatar
PelicanParts.com
Basic Sponsor
pugface, sorry you have to go through this! Your mechanic will diagnose and fix it in no time and you'll be back on the road again enjoying your Porsche.
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old Sep 15, 2014 | 10:31 PM
pugface's Avatar
pugface
Hi guys - thanks for all the replies, and encouragement from other Chicago owners!
Mechanic called today, the water pump is bad, the bearing is shot. Hopefully I got it before any impeller blades went. At least my diagnosis was right! Since before I bought the car, I've been reading through the archives when I have time. I'm back to 2011 currently - I actually have an old post by KrazyK open in another tab. I'm learning quite a bit, and my understanding of the car and diagnostic skills have been tremendously helped by Rennlist. As to my mechanical skills, well, I'd love to be a great shadetree mechanic with a wrench in one hand and a beer in the other, but it seems my skills tend more to the beer and not so much the wrench. I'll keep trying, though!
I think I was being too cute by half in my original post - combining two stories. I'm pretty sure the two events were purely coincidental. Or were they...
joe-1972 - thanks for the kind offer! But I think I need to get a few oil changes under my belt before I move to the next stage.
alpine003 - I was just going to clean the radiators. I got the Pelican 101 book, and that seemed like a simple project to get my feet wet and get more familiar with the car.
KrazyK - No leaks, no overheating, gauge was between the 8 and the 0. I heard the bearing squeal and saw the steam, and pulled over very quickly.
Old Sep 15, 2014 | 11:20 PM
bernardbarbour's Avatar
bernardbarbour
Thanks this story has an easy ending. Just curious, what's your milage.
Old Sep 16, 2014 | 09:41 AM
pugface's Avatar
pugface
A bit over 91K (miles)
Old Sep 16, 2014 | 10:52 AM
alpine003's Avatar
alpine003
Thanks for the explanation Pugface. The thought of radiator cleaning had crossed my mind but didn't want to assume.
Don't worry if you don't have the time/skill/inclination to work on your own car. It seems like you found a good Indy already and DIY isn't for everyone all the time.
Another alternative is to supply the beer and hold a local wrench fest.
Welcome aboard.
Old Sep 16, 2014 | 11:14 AM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Beer and wrenching is a BAAAAAD combination.
Old Sep 16, 2014 | 11:17 AM
joe-1972's Avatar
joe-1972
Glad to hear its just the water pump... my bearing had a total failure and the pulley made some contact with the water pump housing! I replaced it and went with a low temp thermostat while I was in the same area. Please make sure that your Indy checks the impeller... if its the metal one he needs to check the block for any damage... if it the plastic one he needs to check for any damage to the impeller vanes... if they chipped off he's going to need to back flush the whole system to try and clean them out... its not a fun thing to do!
Good luck!
PS. Any Chicago guys going to the meet up this Saturday morning?
alpine003's Avatar
alpine003
True. This is what the factory workers did when hand building our cars, hence all the quality control issues.
Old Sep 16, 2014 | 11:19 AM
joe-1972's Avatar
joe-1972
ROTFLMFAO!!!
Old Sep 17, 2014 | 10:02 AM
MJBird993's Avatar
MJBird993
Originally Posted by pugface
assuming it is the water pump, any preventative maintenance to be done at the same time?
As mentioned, serpentine belt, maybe air filter, how about the thermostat? I'd let your mechanic make recommendations as well, you know, "while you're in there."
Best of luck.
