MKI NB Rear Wheel 54mm Offset Tire
Have spent hours looking for a definitive answer, but answers vary based on suspension heights, offsets and many opinions. I purchased a set of GT3 wheels where the rear wheel size is 18x10 with a 54mm offset. OEM offset for my car I've read is between 63-65mm and others have had success using 295 width tires. I have a 1999 MKI NB 996 with OEM suspension and am looking for the right size tire for the 54mm offset. Hoping for a 295 width tire will fit and clear but with the additional outward offset dimension am not sure if the 295 tire will clear the unrolled fender.
Thank you for your experienced recommendations.
Cheers!
Cheers!
