996 c4s 2003 Trunk !!!
PLease help (Newbie) my trunk has decided to stop working, Battery is fine starts car and the engine cover opens too.
The Trunk started playing up now and then ie would not open then half an hour later it would be fine.
noticed that to day is very hot could that be a cause ?
anyone have a clue on what this could be.
regard Grant
regard Grant
Open up passenger side wheel well liner and you will find a steel cable which is the emergency backup to opening up the Frunk manually. After you get it opened, reroute this cable so it's more easily accessible the next time you encounter an emergency.
I've routed mine so it can be neatly tucked up in the bumper but can be pulled down from the front grill when I need it.
Excellent!!! Thanks for this info Apline003!
Your welcome. You basically want to undo a couple fasteners that hold the shroud down by the frunk latch. After you remove this trim piece, you will be able to see and access the cable which you can fish down through the bumper. You might also find it easier to remove the passenger headlight(easy to do with factory headlight removal tool found with your factory tools) first. Sorry but I really don't take pics anymore like I used to back in the 90's when car forums were a new concept and the novelty was still there.
regard Grant
regard Grant
If you work the latch release button but do not hear anything from the front trunk latch the latch solenoid could be bad, or the button is bad or the wiring from the button to the latch is bad.
Caution: There could be a bad fuse. (I know there is a fuse that controls the engine compartment of my 996 Turbo. I found this out the hard way when I removed the fuse for the spoiler as the spoiler was leaking and I wanted to disable it until I could book the car in to get the thing fixed. But I was unable to open the rear trunk lid with the spoiler fuse removed.)
Thanks guys....when it cooled down opened as normal must be when it gets hot .
I will definitely re route the emergency release cable tho.
Thank you I have had my C4s for 10 days now and I love it the smile on my face never leaves )
