What exactly is the 60k service?
Former Vendor
We offer Major Maintenance Service Kits that include everything you need for the 30,000 miles, and every 30,000 miles thereafter. For more information Click Here.
Own oil-filter, belt, cabin filter is very easy. Buy parts from pelican and follow YouTube videos. I had indie change my plugs for about $300 I think - it is a bit more involved - esp if you are not a DIY guy. Trans fluid change at indie will be relatively cheap too and do brake flush and quick inspection while he is at it - you should be able to get out for < $600. Do used oil analysis with blackstone and inspect filter - this will give you current reading of ims condition. I waited to replace mine until I had rms leak and had to go in there anyway. It was fine.
If you want to stretch the budget you could wait on water pump and coolant for another 5k but this is pretty common failure at these age/miles .. Watch coolant level and for leaks regularly
If you have the budget -
I also had my mechanic do my plugs... I heard that 4 of them are easy to get to but 2 are a total pain... lucky an experienced Indie has done this many times and can do it without much time commitment
