My 3.4L Engine Rebuild
#31
With my camera fully charged and my engine taken apart I have a big update with lots of pics.
Half of my engine torn down
Piston rings need replacing
The IMS bearing is really bad... (lots of play)
other crank case in the hot tank
The following is not my car stuff....... but I thought it would be nice to share..
Jason showed me the difference between cayman s head vs 996 3.4L head
cayman s
3.4L 996
intake ports shaved
crank and bearing case
shaved down to the copper
Transmission rebuild
2nd gear pop out look...
torn up bearings
cayman s
3.4L 996
intake ports shaved
torn up bearings
#33
Thanks for actually taking out the *****, unlike most that just turn them and check it for play. Based on the condition of a few, looks like a rebuild was inevitable soon anyways.
#35
Anyway, yeh looks like the trans was about to self destruct which would have upped your costs even more. Curious, what kind of estimate are they giving you for the total bill?
Keep the pics coming. Awesome job!
On a side note, looks like another DR IMSB failure was coming. Thought these were rare but it seems theres been a few posted recently of the "low risk" engines.
#36
Captain Obvious
Super User
Super User
#37
Never thought I would see you type that Alpy.
Sounds good. Let me find out how much the shipping is and I'll let you know.
#38
#39
My build Monday update....
Thrust washer old and new.
before Jason took off the right side guide rails
Right guide rail old vs new.
The left side is abnormally not as bad as the right side.
The IMS bearingas a lot of play
** The following is random photos **
Track 996 with Leather Recaros
Boxster engine bay with the 3.8L build
View from interior
View from interior
#40
So the chain rails were really grooved down. And the IMSB had a lot of play! What did the bearing itself look like?
2002 Turbo - Basalt Black Metallic / 2003 Carrera 4S - Speed Yellow / 1955 356 Continental 1500 - Rust Red
#42
There were no obvious signs of what the intermix problem could have been. The heads were sent out to be pressure tested and resurfaced. I will find out tomorrow or Thursday when the heads come back from the machine shop.
#44
