996 Forum 1999-2005
Another PSE Q
Old Aug 5, 2003 | 02:34 PM
Palting's Avatar
Palting
Default Another PSE Q
PSE just arrived today. Aside from the mufflers, there were two other boxes, with cables, probable vacuum lines, and assorted hardware.
Question for those who had it installed without the electronics. I just plug in the mufflers where the old ones used to be, right? No need to connect anything else that was not connected on the old stock exhaust?
Old Aug 5, 2003 | 02:52 PM
Paul in CA's Avatar
Paul in CA
Yep. Did not use anything other than the two mufflers. Not even the mounts. The existing mounts worked fine.
Old Aug 5, 2003 | 03:05 PM
Palting's Avatar
Palting
Thanks, Paul.
Old Aug 5, 2003 | 05:04 PM
AdamB's Avatar
AdamB
Hey Palting, where did you end up ordering your PSE from? The reason I ask is that the best I found is probably Suncoast Porsche at around $1650. That is a good price, but I've definately seen a lot better posted in the past. If there isn't anything better I'll just go ahead and purchase.
Old Aug 5, 2003 | 08:25 PM
Palting's Avatar
Palting
Sent you a PM, Adam.
Old Aug 5, 2003 | 09:58 PM
mb996's Avatar
mb996
Default PSE price?
Palting,
I am also scouring for the best deal...can you let me know too?
thanks
