Oil Changes
macster,
Great answer and thanks. I tend to think that people change their oils more frequently than necessary. It is not 1966 anymore and oils and engines are just a lot better than they were when 3,000 miles was the standard.
Higher heat exposure and increased fuel/oil mix even in healthy engines, according to what I've heard. Oil with fuel in it doesn't lubricate as well. After every track day is a little excessive in my opinion, unless you're running a turbo car that's washing down the cylinder walls with fuel. If you are, you should likely fix that.
http://www.bobistheoilguy.com/oilshear.htm
