Got 3 codes today 02096 ,6403, and 00225
First one says ring break diagnostic-02096
Second 6403
Third 00225-unlock rear lid lock ejector
Any help will be appreciated
Second 6403
P2096 - Upstream Bank 1
Signal Delay Time for Oxygen Sensor Ageing - Above Limit
Diagnosis conditions
Oxygen sensing after TWC is active
No secondary air
No diagnosis of secondary air system
EVAP canister not highly loaded
No faults in memory
Possible fault cause
Oxygen sensor
Diagnosis/Troubleshooting
NOTE: Do not use contact spray on the connectors to oxygen sensor.
