996 Forum 1999-2005
Locking with key only locks driver door
Old 04-01-2014 | 07:47 PM
kc944's Avatar
kc944
Default Locking with key only locks driver door
Hi my last good remote key fob is dying so I have resorted to locking the car manually with the key for the time being.(1998 996C2 UK model RHD)
When I lock the car via the keyhole in the drivers door, the driver door locks but the passenger door never does. The passenger door does lock when I manage to get the remote fob to work by fiddling with it so I know the pass door lock is OK.
When I lock the car manually with the key the following happens:
1)the drivers door locks
2) the pass door and gas cap do not lock
3)the instrument pod lights go out (suggests signal is getting from the door to the dash )
4) Interior light doesn't go out- stays on for the normal length of time
5) Alarm doesn't arm
when I unlock the drivers door manually using the key:
1) Drivers door unlocks
2) Interior light comes on (before i open the door)
The lock button on the dash locks both doors everytime no problem
I was originally going to start investigating at the drivers door lock however now I see that the dash lights and the interior lights react to the key being turned make me think the problem may be elsewhere. any ideas??? thanks.
Old 04-01-2014 | 08:44 PM
Macster's Avatar
Macster
That is the behavior my 02 Boxster has and I think my 03 Turbo. I think it is normal behavior not something amiss. The behavior is probably covered in the owners manual but I have not bothered to look for it.
Update: I did look for the info in my Turbo's owners manual and didn't find anything on this behavior. At the car I did not try to turn the key in the lock several times in rapid succession to see if this locked the passenger door.
Old 04-02-2014 | 03:44 PM
kc944's Avatar
kc944
I never even thought of that option! you may well be correct ,I'll need to check my manual and see if it mentions anything. Might have to shell out for a new remote sooner than later . Thanks
Quick Reply: Locking with key only locks driver door
