996 Forum 1999-2005
Is an annual brake flush a must do?
Old 03-26-2014 | 09:43 AM
adcampo's Avatar
adcampo
Default Is an annual brake flush a must do?
I know annually is recommended by Porsche. Thoughts about coolant flush frequency. My car has 33k miles. Has had a brake flush about 18 months ago and I'm assuming a coolant flush in its lifetime.
Old 03-26-2014 | 09:52 AM
Imo000's Avatar
Imo000
Captain Obvious
Super User
No.
Old 03-26-2014 | 10:04 AM
LexVan's Avatar
LexVan
Brake fluid interval is every 2 years. Not yearly.
Coolant, replace at the same time you replace the water pump. About every 4-6 years, depending on your risk tolerance level.
Old 03-26-2014 | 10:05 AM
LexVan's Avatar
LexVan
Old 03-26-2014 | 10:32 AM
Zanzibar Red 996's Avatar
Zanzibar Red 996
Only required if you use brakes
Old 03-26-2014 | 10:39 AM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Brakes are for quitters!!
Old 03-26-2014 | 11:14 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
Porsche recommends changing the fluid every two years for normal driving. Most people who track their cars change it more frequently. The concern with brake fluid is that it is hydrophilic. If water gets into the fluid, it reduces braking efficiency and it can corrode brake components. This can happen even in a car that is just sitting in a garage.
You can change it every two years, or a good mechanic can analyze your brake fluid for water content and let you know if your fluid is okay or needs a change.
Old 03-26-2014 | 11:22 AM
adcampo's Avatar
adcampo
Good info. Thanks all.
I do use the brakes some. Mostly when I power brake for my launches. I'll have my guy check the fluid for water content and make a decision.
Old 03-26-2014 | 11:32 AM
alpine003's Avatar
alpine003
Waiting for KK to chime in on this one.
Never Lift!!!
Old 03-26-2014 | 11:34 AM
Sneaky Pete's Avatar
Sneaky Pete
Better yet....it is an easy DIY. That way you can see what kind of damage you are doing with your launches....
Old 03-26-2014 | 01:04 PM
adcampo's Avatar
adcampo
Stand on brake, heal/toe gas to 6k rpm's and dump clutch. The car will actually explode. Very cool and fun to do. Just kidding.
Old 03-26-2014 | 11:34 PM
DK570's Avatar
DK570
What fluid is everyone using? I had planned to switch to blue fluid when I flushed the system to easily identify the new stuff, but that's no longer an option. I recently posted this chart in another thread:
I guess because of the ABS system, SL6 would be the preferred fluid?
Old 03-27-2014 | 12:00 AM
Sneaky Pete
I have had good things with Motul 600.
Old 03-27-2014 | 12:22 AM
Ahsai's Avatar
Ahsai
For street driving, ATE TYP200 is more than good enough every few years. No problems with ABS and PSM.
Old 03-27-2014 | 12:46 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
ProSpeed RS683.
Quick Reply: Is an annual brake flush a must do?
