P1314 code thrown
#32
Another Update: Successfully replaced#1, #2 and #3 plugs and coils, which included the suspect #2 coil. I started up the engine and voila! Check engine light immediately went off and the engine is back to running normally. Looks like the #2 coil was the problem as suspected. I'm just happy the problem wasn't something more serious like a sticking valve.
Thanks for all your help guys. Soon I will swap out the coils/plugs on the other side of the engine but the bad #2 coil issue that caused all of this is solved.
One lesson learned here is that both the Primary and Secondary coils inside the ignition coils can be tested with a multimeter. I've seen very little documentation that shows this.
#34
So I have finished installing all new coils and plugs and (wait for it)... the engine is purring like a kitten. Nice and smooth. I suspect that the five old "good" plugs/coils were working but maybe not optimally.
#35
On these coils the Primary Coil resistance is tested between terminals 1 and 15 and should have a value of 0.4 to 0.7 Ohms. All three of mine had a value of .7 ohms, so no problem with the Primary coil.
Next up the Secondary coil test. From what I can tell, terminal 4 to the spark plug contact point is the Secondary coil. I measured 18k ohms on both the #1 coil and the #3 coil. On the #2 coil I measured an open circuit! Pretty sure I found the problem here. It seems that the secondary coil in #2 is shot.
http://www.autozone.com/repairguides...96b43f80376169
It would be great if sjg1138 could post his procedure. That should be a sticky for every subforum that involves this type of coil so that people are aware of it and don't replace coils unnecessarily.
#37
Best to ask in the Cayenne Forum because the answer does not apply to this Forum.But this may help
https://www.picoauto.com/library/aut...urrent-4-wire/
This is the generic info for 3 wire coils
http://easyautodiagnostics.com/misc-...n-coil-tests-1
#39
https://www.youtube.com/watch?v=y7YMMlR8wc4
https://www.youtube.com/watch?v=PR3enE7UsLA
