Door rattle 2004 C4S Cab
Door rattle 2004 C4S Cab (FIXED)
Guys
When I hit bumps the drivers side door in the latch area rattles. You can actually see it bounce up and down. Don't get that from the passenger side. Could the door latch be bad?
Thoughts?
Thoughts?
Is the window working properly? It is supposed to go down~1/4" when the door is opened and pop back up when the door is shut. If it isn't down prior to closing the door, the door won't shut fully and that would cause a rattle.
Guys, I fixed this. I raised the door latch (on the body not the door) to its max height and it closes firmly and does not jump around.
Makes sense after so many years of being beat down. Hope this helps someone else.
