996 Forum 1999-2005
Suspension differance
Old Mar 5, 2014 | 03:47 PM
Dannyfumi's Avatar
Dannyfumi
Default Suspension differance
Hi All,
Anybody know if the my 01 turbo suspension different from stock my 01 carrera suspension?
Old Mar 5, 2014 | 04:29 PM
white out's Avatar
white out
2WD and AWD are different. Not sure if there's a difference between Turbo, C4S and C4 though.
Old Mar 5, 2014 | 06:07 PM
MiamiC70's Avatar
MiamiC70
Turbo is heavier car
Old Mar 5, 2014 | 06:14 PM
Dannyfumi's Avatar
Dannyfumi
Any benefit to using turbo suspension on a c2?
Thx
Old Mar 5, 2014 | 06:24 PM
alpine003's Avatar
alpine003
Thx
You can use the beefier Turbo brakes and it has more robust wheel bearings IIRC.
Or, you can put some 6 piston GT3 calipers on. (just make sure to use dummy axle ends if you are 2wd).
Old Mar 5, 2014 | 09:26 PM
Dannyfumi's Avatar
Dannyfumi
Thanks, can you use the Turbo struts and Springs on a carrera?
Old Mar 5, 2014 | 09:40 PM
6ta1's Avatar
6ta1
no, turbo struts are at an angle to clear the driveshafts.
what you really want is a GT3 or GT2 spindle/hub carrier so that you can get the big brakes and not ahve too many other parts to change.
also the geometry is worse on the turbo vs. base c2 or gt3, again due to the necessity to clear the driveshafts.
Google posts about upgrading brakes and you will find tons of info
