Gear Oil Change
Gear Oil Change
I want to change the Gear Oil in my Trans, I am at 105K on it since last changed at 90k not going to wait till 144k Interval like Porsche says. Last time was does at Porsche with OEM Fluid.
Which Gear Oil shall I use? car is a DD with Track Time and Cold Canada Winter days.
Porsche?
Motul?
Mobil 1 Delvac?
Mobil 1 Mobilube PTX?
Liqui Moly?
Redline?
Fuchs?
Eneos?
Royal Purple?
Also OEM Porsche Fluid is repackaged Liqui Moly? or Mobil 1 Delvac or Mobilube PTX?
Porsche?
Motul?
Mobil 1 Delvac?
Liqui Moly?
Redline?
Fuchs?
Eneos?
Royal Purple?
Spent a lot of time researching this. I assume you mean the manual trans. The only approved is the porsche OEM and one other I could not find to buy. They do not say waht spec it is, just porsche special.
Some people are using the mobile 1 synthetic
Also redline has one they say is approved but is it the same price as the OEM.
Renntech has lots of info.
Any synthetic gear oil of the recommended weight will do just fine. The "porsche approved" is a marketing BS. You are really over-thinking this.
On my car, I put Royal Purple in the differential after I got, it works fine.
Received 5,404 Likes
Mobil Delvac 75W90. Send a sample of your drain to Blackstone for a UOA.
If you changed the fluid at 90K and it only has 15K miles on it it is premature to change the fluid again this soon.
But if you want to…
Since the OE fluid has gotten the tranny to 105K miles with no issues I fail to see what you can gain by switching away to another (need I say unapproved?) fluid at this time.
Furthermore, I fail to understand why every one it seems is so willing to offer up their car as a test bed to test some other fluid. I do not know what is to be gained and the risk is an expensive transmission rebuild or replacement should the replacement fluid be inadequate.
The OE fluid certainly isn't inadequate. My 02 Boxster's 5-speed has covered over 277K miles with just scheduled transmission fluid changes using the stuff dispensed by the dealer's service department. Takes less than 3 liters and 0.3 hours labor. The Turbo requires a bit more fluid and a bit more labor but its 6-speed is up to 118K miles and will continue to receive regular changes of the OE fluid.
Maybe you ought to wait until someone else runs Redline or Royal Purple 277K miles with no transmission issues before you switch?
But if you want to…
But if you want to
But if you want to
I agree with the remainder of your post.
If you use this be ready for very hard shifting when the trans is cold.
The Motul 300 75W/90 worked well for me.
http://www.powersportsuperstore.com/...tm?Click=35177
Former Vendor
If you check with many of the indie shops they are using 1 of 3 options.
OEM replacement: Mobil
DE Track/DD: Motul
Heavy Track: Redline (we have a special mix ratio we use for track cars)
At the end of it all it really is how much you want to spend and how often you change the fluid.
If you car is only sees a fluid change every 100k... then the Mobile option best suites the situation.
Technical Guru
Originally Posted by LC Motor Sports
That is not true at all.... We use it in all our customer cars. No one has ever experienced very hard shifting. Especially here in CNY were you have Extreme cold temps both in the early spring and late fall driving season.
