newb question about tail light bulb.. did searc
even looked in the manual. But there are too many different numbers for parts on different sites and designations and i dont know jack about them. what bulb do I have to get to replace this? the break lights work.. this is just the normal tail light that comes on when lights are turned on.
please and thanks!!
![](http://i42.photobucket.com/albums/e349/supernareg/photo_zpsad8c189c.jpg)
can someone post a link of the exact bulb I need to order? thanks!
please and thanks!!
The good news is that this is probably the easiest job on the entire car. The OM shows how to do it - just take a 10mm socket and remove the two bolts on the inside of the tail light (when you open the rear bonnet) and the tail light slides right out towards the rear.
I forget the exact bulb, but you'll see the number on it when you remove it. They might be in the OM as well. Pep Boys has a great selection of bulbs - the exact brand and model that is called for.
Fwiw, they're so cheap that I just replaced all of them when I did this a few months ago. Only a couple bucks each.
