996 Forum 1999-2005
Dimming Dash Lights
Old Jan 31, 2014 | 04:00 AM
sjg1138's Avatar
sjg1138
Default Dimming Dash Lights
My dash lights seem get brighter and darker with the speed of the engine. It seems to happen the most when the Headlights are on. I dont really notice it with the headlights off. The Voltmeter seems to hold steady at 13.5V.
Any ideas what could cause this? I was thinking voltage regulator on the alternator or a corroded alternator cable or maybe a bad headlight switch...
Old Jan 31, 2014 | 04:44 AM
Stephen Tinker's Avatar
Stephen Tinker
This can be caused by either 1) voltage drop due to a poor connection (high resistance) to ground, or 2) a faulty voltage regulator, or 3) a failing battery.
If you have a digital multimeter (don't rely on the dash volt guage), connect across the battery terminals with the engine off and check the voltage (v) - should be 12,6v for a fully charged battery. Start engine & check (v) - should be +/- 13.5-14.2v. Finally switch on headlights and check (v) - should still maintain 13.5-14.0 volts.
Another symptom of a poor voltage regulator is when your lights "pulse" @ engine idle.
Old Jan 31, 2014 | 11:53 AM
sjg1138's Avatar
sjg1138
Thanks Stephen.
The battery was replaced 6 months ago so I doubt it is the problem. I think the lights may be "pulsing" @ idle like you mention. I will confirm and will run the tests as you suggest.
Replacing the voltage regulator and the cables to the alternator seems like a painful process, at least from the DIY on RennTech.
