Center Console Removal
Seems easy enough..right?
Well, I have a Tip. And the shifter **** is in the way of removal of the center console.
Do you know if it just pops off once pressed down? Any advice appreciated.
![](https://imagizer.imageshack.us/v2/320x240q90/42/pcfc.jpg)
Pry off the silver part you press on, with a plastic trim tool. then there is a wire clip to remove with a pair of needle nose pliers then the body slides up.
