Voltage/Rev Drop at Stop [VIDEO]
Ok, sounds like you have some fundamental problem in your alternator/regulator/cables. After you make sure your battery is fine, you can further diagnose it based on posts #2-9 here http://www.renntech.org/forums/topic...er#entry240001
I had the same symptoms before and my alternator was on its way out... Definitely check your cables and terminals for corrosion.. Also just disconnect your SAI and test.. This could be a quick way to test if the SAI is the culprit. It only happens when the clutch is pushed, correct? I'm thinking the alternator/ regulator is having difficult time managing changes in load and rpm from the engine
