996 Forum 1999-2005
Yellow Fluid Drip
Old Jan 13, 2014 | 11:48 PM
uswrnk54's Avatar
uswrnk54
Default Yellow Fluid Drip
When my car sits for more than a few days there is a yellow fluid that drips on the garage floor under the motor (sorry not good at posting pics to Rennlist). It doesn't appear to be motor oil though I could be wrong. Oil level doesn't seem to fluctuate on dipstick. Have not taken the time to jack the back of the car up to crawl underneath it to check for wet spots. Wondering if anyone knows of a common leak of a yellow-ish fluid.
Thanks (again) ahead of time.
Old Jan 14, 2014 | 12:20 AM
5CHN3LL's Avatar
5CHN3LL
May be the coolant. Check the reservoir to see if the coolant in it is the same color as what's on your floor.
Does it evaporate? If so, you know it's not oil.
Old Jan 14, 2014 | 03:37 AM
uswrnk54's Avatar
uswrnk54
Crawled under my car. It's coolant. Coming from H20 pump housing (good call 5CHN3LL). Any chance it's just the gasket or do I likely need H20 pump too? If I elect to replace the pump, I've seen $250 - $350 units at ECS & $110 units on Ebay (including the gasket). Is this a part I should take a chance on?
Old Jan 14, 2014 | 03:57 AM
Ahsai's Avatar
Ahsai
If it's the original pump, it's due for replacement (as preventive) anyway. I think the stock pump from Sunset Porsche is no more than $300.
Old Jan 14, 2014 | 04:34 AM
kromdom's Avatar
kromdom
Originally Posted by uswrnk54
Crawled under my car. It's coolant. Coming from H20 pump housing (good call 5CHN3LL). Is this a part I should take a chance on?
IMHO, NO! FWIW, I went with OEM when I had my tank replaced (along with cap, WP, belt, hoses/lines and t-stat).
Old Jan 14, 2014 | 08:02 AM
sandersd's Avatar
sandersd
If it's leaking or the pulley is wobbly, definitely replace the pump before it fails. This is the voice of experience talking.
Old Jan 14, 2014 | 10:21 AM
relinuca's Avatar
relinuca
Default OEM is a good choice
FWIW, except for IMS bearings, I strongly favor OEM parts for "mission critical" components, and water pumps certainly fit that category.
I don't think I've ever heard a Porsche owner say, "Gee, I wish I had installed a cheaper, after market part."
relinuca
Old Jan 14, 2014 | 12:23 PM
Ahsai's Avatar
Ahsai
Also, if your fluid is original, it's also a good time to flush the coolant and change it to the newer OE pink coolant.
Old Jan 14, 2014 | 01:50 PM
uswrnk54's Avatar
uswrnk54
Thanks guys. Got a new H20 pump on order.
