Differences in OEM catalytic converters
Hey all,
I have a US (California) 3.6 996 C2 (2004), which I have imported to Germany Problem is, the catalytic converter has totally failed, and I need a new one. They are $2k EACH from Porsche in Germany, and none of the aftermarket options will pass the TÜV (it has to be an original Porsche part.) Even amongst new ones, there is a big price difference: 99611303102 costs €1750, while 99611302112 only costs €1050.
There are quite a lot of used versions available, but many different part numbers. Does anyone know if they are all compatible? What's the difference?
I am trying to see if there is a (used) cat here I the EU that will fit on my car. I think only OBDII cars have two O2 sensors (pre- and post-cat), correct? But beyond that, are there any differences, or are they all the same thing basically?
Here is the full list from the German porsche site. As I understand them, parts 21 and 22 are just the left and right side of the same part, respectively. So eliminating duplicates, the list is:
Here is a different list from the US parts catalog
And here is another list from the EU parts catalog:
996 113 021 12 Z KATALYSATOR ZYL.1-3 1.020,65 €
996 113 021 56 Z KATALYSATOR ZYL.1-3 1.377,15 €
996 113 021 59 Z KATALYSATOR ZYL.1-3 1.378,64 €
996 113 021 60 Z KATALYSATOR ZYL.1-3 1.377,15 €
996 113 021 93 Z KATALYSATOR LI ZYL.1-3/ 1.377,15 €
996 113 021 97 Z KATALYSATOR LINKS RD 1.473,48 €
996 113 023 06 Z KATALYSATOR ZYL.1-3 1.473,48 €
996 113 023 07 Z KATALYSATOR ZYL.1-3 1.473,48 €
996 113 025 03 Z KATALYSATOR ZYL.1-3 1.550,21 €
996 113 025 04 Z KATALYSATOR ZYL.1-3 1.473,48 €
996 113 031 02 Z KATALYSATOR ZYL.1-3 1.752,43 €
996 113 031 06 Z KATALYSATOR ZYL.1-3 1.752,43 €
996 113 021 53 catalytic converter -99 1 M660
996 113 021 56 catalytic converter -99 1 M660
996 113 031 01 catalytic converter 00 1 M660
996 113 031 02 catalytic converter 01- 1 M660
996 113 022 53 catalytic converter -99 1 M660
996 113 022 56 catalytic converter -99 1 M660
996 113 032 01 catalytic converter 01- 1 M660
996 113 032 02 catalytic converter 01- 1 M660
996 113 021 54 Katalysator -98 1 M499
996 113 021 57 Katalysator 99- 1 M499
996 113 021 56 Katalysator 01 1 M661
996 113 021 52 Katalysator -98 1
996 113 021 55 Katalysator 99- 1
996 113 022 54 Katalysator -98 1 M499
996 113 022 57 Katalysator 99- 1 M499
996 113 022 56 Katalysator 01- 1 M661
996 113 022 52 Katalysator -98 1
996 113 022 55 Katalysator 99- 1
I'm not sure how much lax German emissions are but another option since you're already in Europe is to have Gert at Carnewal rebuild your cats with cell 200 cat cores.
http://www.carnewal.com/products/P96...-to-Sport-Cats
didn't know about this either - I wonder if there is someone doing the same in the US?
on the original question, I had done a bit of research on the topic and although I couldn't find a definitive answer, my understanding is the both EU and US cats fitted on the 996 are 3-way cats but the metal composition of the cat itself is different, due to legislation constraints.
Here is from the 996 buyer's guide:
Reason for researching this is that 3-way catalytic converters need "help" from the ECU to stay clean and not wear prematurely. I am still not sure if the ROW tune is compatible with US cats or not.
Emission control system
Exhaust system
2-pipe, 3-way catalytic converter exhaust system
2 rear mufflers
EURO II
Oxygen sensor closed-loop control with 2 pre-catalytic
converter probes
3-way catalytic converter sytem each with a catalytic
converter left + right. (RoW)
EURO III
Additional secondary air system and post catalytic control
(4 probes)
EOBD
USA LEV
Oxygen sensor closed-loop control + post catalytic converter
control
3-way catalytic converter system, each with 1 cascade
catalytic converter - left + right. (with two metal substrates)
Secondary air system
OBD II+ ORVR
Exhaust system
2 rear mufflers
EURO II
converter probes
EURO III
(4 probes)
EOBD
USA LEV
control
OBD II+ ORVR
