Fog lights
Only used them for the first time last night.
They look a dirty yellow color when turned in. Headlights are very clear white.
Is that normal for the fog lights? Different wavelength of light to cut through the fog I assume?
The difference is the different bulbs types (fogs are not Xeon).
If you still have the original bulbs new ones would probably be brighter, but they will still be yellower than your low beams.
I found out that some MKIIs came with Halogen projector headlights - meaning that they look like HID Bixenons but they are regular H7 halogen bulbs behind projector lenses.
Really? That's annoying (from trying to figure out what you have).
Based on his description (headlights are whiter) I suspect he does have the HIDs though which would explain the color difference.
Rocky Mountain High
If you intend to use them as a true fog light, then a bulb with a lower color temperature (like the standard OE bulb) will provide better visibility than a "whiter" light. If you want to use them as driving lights or simply want a certain look, then try to find a bulb that has a color temperature closer to the OE HID lights, which is 4,300 K.
Rocky Mountain High
It is perfectly normal.
I only use mine in the fog, so I've got standard bulbs in there. For performance could be improved even more with a true yellow bulb, but I agree with you - they aren't very bright.
