Oil pressure gauge issue
I drove my wife's 996 this evening and noticed that the oil pressure gauge was above the top mark of 5. So I stopped and turned the car off. The gauge went to 0. I turned the ignition to position 2 but didn't start the car yet and the gauge shot up to above 5. And the same reading when it started.
When I got home I tried the same on my 996 and the gauge stayed at 0 when the key was turned to position 2. It normally sits around 4 when driving (if I recall correctly).
Any idea what might be causing this? A faulty gauge or sensor? Or something more serious?
Oil pressure sending unit. Google for it. Easy DIY, you'll need a crows foot wrench, and it easiest to access by removing passengers side rear wheel.
Good luck,
DS
Good luck,
DS
