Gearbox oil
Gearbox oil
hi,
im currently changing the gearbox oil on my 1999 C4, so far it has taken 2.8l and nothing has came out the fill hole yet, Car is sitting level. Should I keep filling or stop? 1999 C4 manual
thanks
thanks
Hi guys,
Put all 3l in and still no sign of it, All back together and seems fine, smoother shift. I have heard various volumes but im thinking if t was slightly low on the rear it would take more therefore maybe slightly over filled.
cheers
cheers
sounds like too much... are you positive you're using the right fill plug? Check diagram
http://www.renntech.org/forums/tutor...-instructions/
