Oil looks Dirty after change
We had a jeep one time went in for an oil and filter change . I took it and the guy after about half an hour said 'OK you can take it now' So I drove across the car park and the sound of the engine did not sound right. I do not play music when driving but my wife always does. Its a good job it wasn't my wife driving it as I heard a loud whistling and on checking my rear view mirror, saw the owner waving frantically and running across the car park. They had completely forgotten to put new oil in the car after dropping the old oil. The owner thought his son had put new oil in and the son thought his father had put new oil in. Neither had, so there was I setting off in a jeep Cherokee with no oil in the engine. Needless to say that was the last time that I ever used that garage.
Savorystout I use the same oil as you do in the Porsche...changing it every 5000 Miles along with a new filter. I too buy it on line from Amazon.
Oil can darken pretty quickly after a change, especially if they didn't warm the engine/oil thoroughly before draining and/or let it sit for a while after removing the drain plug to drain out as much of the old oil as possible. Neither step is a tech highly incentivized for as he (she?) needs to churn and burn cars through his rack to make any money. ...
I was also thinking there may be some baffles or something in the location from where I'm taking the sample. I just put a hose down the dipstick tube and pump-out a few ounces. To test this I went for a short drive on some twisty roads before taking another sample, but there was no difference in the color from the 2nd sample.
Hey Targa996, do you take samples or is the 1k and 3k color just from the dipstick or drops on a paper towel?
They might have just sucked the old oil out through the dipstick or fill tube. That is the way the Mercedes dealer did oil changes when we took ours in for the "free" oil change every 10k during warranty period. The oil always looked dirtier then at the 5k interval when I changed it. I changed it at 5k so every other, half assed dealer change (IMO), was free.
It is somewhat deceiving as looking at the dipstick or some drops on a paper towel does not show the oil as dark as a larger sample. You can see this in the first pic if you look at the cap of the sample bottle.
Exactly the opposite thinking. It always looks darker filled in a bottle even though the oil might be relatively new. However if you pour some drops on a paper towel, you can tell its true condition between a 5k oil vs. 100 mile oil even though they both may look dark in a bottle.
I can try to get pictures of a comparison with drops on a paper towel, though I think the camera may not pick it up well.
I just changed my oil 221 miles ago with Mobil 1 0W40. The oil on the dipstick looks light and clean, in clear plastic tubing like dark honey, and in an oil analysis container much darker.
Received 5,407 Likes
I just took a sample from the dipstick tube so the OP could see that oil looks dark even after a fresh change. Took out 3 ounces, and will put 3 fresh ounces back in. In other words, the dealer probably changed the oil and filter, and Mobil 1 probably changes color as soon as the engine reaches operating temps and the oil runs through the system.
As you will recall from my Blackstone report, my last oil change was at 58xxx miles on Oct 8, and I've only put another 221 miles on since. I used an oil extractor to pull this sample from the dipstick tube (which is how I change the oil on our Mercedes C350). For the porsche, I drain from the drain plug and change filter each time.
I was just trying to provide "data," to ease the OP's concern about his recent dealer oil changes. Of course, it is really easy to change oil on the 996, and I would encourage the OP to watch the video, buy some rhino ramps, an oil filter wrench, oil drain pan and socket set and/or torque wench and do it in about 20 to 30 minutes tops on his own. Then the OP will know for sure the work was done, and for about 70 bucks (not including the getting started costs). I personally had never changed my own oil on my cars, until I paid a Porsche dealer once to do so, and vowed never again. If I can do it, anyone can. And you can't beat 70 bucks, and with those savings you can all send in a sample to blackstone for 30 bux with TBN and post your reports.
Guess I could have, but I dumped it into my oil container without thinking much about it. I'll consult the Talmud, the New Testament and BITOG to see what they all say.
The good thing about our cars is you don't even need a jack or ramps to change the oil. My car is lowered and I'm still able to reach everything without lifting the car.
.... In other words, the dealer probably changed the oil and filter, and Mobil 1 probably changes color as soon as the engine reaches operating temps and the oil runs through the system...
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Thank you sds911! This is exactly what I was looking for. I'll buy you a beer the next time I'm in your area, ever go to San Manuel? I stop there sometimes when I'm passing through for the holidays.
... Of course, it is really easy to change oil on the 996, and I would encourage the OP to watch the video, buy some rhino ramps, an oil filter wrench, oil drain pan and socket set and/or torque wench and do it in about 20 to 30 minutes tops on his own. Then the OP will know for sure the work was done, and for about 70 bucks (not including the getting started costs). I personally had never changed my own oil on my cars, until I paid a Porsche dealer once to do so, and vowed never again. If I can do it, anyone can. And you can't beat 70 bucks, and with those savings you can all send in a sample to blackstone for 30 bux with TBN and post your reports.
I recently saw the video and have most of the tools as I change the oil in my other cars. I was somewhat wondering about the angle of the car with the rear wheels on the ramps. Do you leave the front wheels on the ground or jack up the front or ???
Thanks again,
The photo of sds911 paper towel is what I was talking about. Even if the oil "looks" dirty in a cup or container it will still look pretty clean on a paper towel if it's low mileage. It would look a lot more dirty than that on a paper towel for example if it had 5k miles on it and that's the reason why I asked if you tried some drops on a towel.
Captain Obvious
Super User
Super User
