Question for those who have polished their headlights
My headlights look awful so I'm going to polish them myself and then apply an Xpel film to protect from future damage.
The question I have is, did you remove the headlight washers when you did the procedure or just tape them up?
If you did remove it how is that done without destroying them?
Going to do mine this weekend and have the same question! One of my washer covers flew off and I have a replacement I'll put in when done, but for the other side I was thinking of just trying to pop it off so I wouldn't have to worry about it.
The other thing I wonder is why people don't just remove the lights for the polish. In the DIY videos I have seen it seems folks just leave the lights on the car and tape up the paint all around. Considering how easy it is to just remove the lights why not just pull them off and do it on a table top or vise?
I plan on leaving mine on the car myself even though as you mentioned it's easy to remove them.
Mine are really bad now so I'm looking forward to getting this done. Then next month I'm sending the car to be detailed for the first time in years. Since I've not been tracking the car lately (just had a baby) I figured I might as well try to make it look better.
The 3M kit will not be sufficient if your headlights are in bad shape. You can use the kit after you start with some more aggressive sanding. I tried it initially and end up starting at 1000 grit to get good results.
http://g-ecx.images-amazon.com/image...Z5HY.02.lg.jpg
Not my car but my headlights are in similar condition.
Mine can still show light without blockage but you can see that the layer on top is starting to break down. But I've seen some where barely any light comes through - that's not what mine look like.
Any idea as to whether this is too far gone for the kit?
I removed mine from the car and also removed the headlight washers. I had to really go to town on my headlights to get them back into shape and I didn't want to risk chewing through the tape and scratching my paint.
If you can dig your fingernails into any of the pits/imperfections on the lense, you're gonna have to start with low grit, possibly down to 400 as someone mentioned.
If its hazy and nothing more, you could get by with a 3m kit.
Just got this email from Griot's Garage, seems interesting.
http://www.griotsgarage.com/product/...do?code=EMABPB
Video http://www.griotsgarage.com/text/con...storation.html
FWIW, my headlights were lighted pitted but looks good otherwise, I elected to just install the Xpel film over the lens after a light cleaning, the adhesive fills into the light pitting, and I can no longer see ANY pitting that was on the headlight cover under the Expel film, I'm amazed to say the least, and the headlights are now protected by this thick headlight protection film.
What brand of UV protectant are you guys using? Mine aren't too bad but are developing some crazing. I was going to use my high-speed rotary for starts to polish them before I went crazy with sandpaper or something like that.
Fernando, haven'tseen you at either autocross or DE this year. Hope all is well.
A couple of points already mentioned that I want to go back to. When I did mine, I removed them from the car. Very simple and IMO makes getting to the edges easier. Go get a piece of 500 grit wet sanding paper to start the process. Keeping everything wet is key. Do it "north-south" and then "east-west". When you think you have ruined the lens, you are done with the 500 grit.
Now start with the 3M kit and follow the directions. You will be stunned at the results after the final polishing compound. Here is what I did and posted over on the other BB. http://tinyurl.com/nycwsg8
Let us know how easy the Xpel film is to apply.
IMHO
In re. "what UV protectorant are you guys using"...the XPEL overlays are the real deal. Once applied, they provide UV protection AND protection from rocks, corrosive insect splashes, etc. I think these are far more effective and longer lasting than any spray-on protectorant.
relinuca
relinuca
Thanks for the recommendations on the sanding. I'll start off with the rougher grit as others have mentioned here then I'll move on to the 3M kit.
As for the Xpel I watched the video a few times so tonight I'm picking up a heat gun as that should help a bit. I'll let everyone know how it goes and will document the process with photos.
Wow I'm going to have a busy weekend - oil change, headlights, and have to overseed the lawn. All of this has to take place on Saturday as Sunday is reserved for football.
