Reverse light switch
Will Pete, here I am not even two years later with a leaky switch by going the aftermarket route.........., it may have been slowly leaking for quite sometime, but only finally started dripping onto the garage floor this year.
Guess I will pony up for the OEM switch this time!
The filler hole is on the side at the top. You top up the oil till it runs out the hole. You will need a separate squeezable bottle with a plastic bendable spout as there is no room to pour the oil into the hole. Obviously if you plan on changing the transmission oil totally, the release oil plug is lower on the side or under the transmission casing.
Don't be so quick to judge!!
Lesson learned today, well actually from yesterday but did not realize until today, is:
"DO NOT JACK UP ONLY THE REAR END OF THESE 996 AND REMOVE THE REVERSE SWITCH"
A big puddle of transmission fluid on the garage floor awaits me when I got home today is why I should have also jacked up the front end of the car yesterday......
Just pluck the transmission out and you won't need the squeezy bottle with a bendable spout. You can just turn the trans on its side and pour the oil in.
http://www.renntech.org/forums/tutor...-instructions/
Could you please share your source of this info? I've never heard of that and the factory procedures call for filling to the bottom edge of the fill hole
It was from Pelican Tech Articles, I had also come across that a couple of days ago, although it's under the "911" grouping so potentially it's for older air-cooled 911 vs. the water-cooled 996.
Here's the link http://www.pelicanparts.com/techarti...sion_Fluid.htm
I think I would go with even to the bottom of the fill hole approach on Renntech under 996 heading.
Ahsai,
BTW, I looked on-line and locally for a quality replacement switch, believe it or not the same switch is used in early 2000' vintage Cadillac and SAAB and (gulp) Pontiac vehicles, so there are many crossed numbers and options, anything from $10 to $50.
Pelican Porsche unit would be $22 + S&H
Decided to call the local Porsche dealer near my house this morning, $25 + tax, I was sold.
The switch arrived at the dealership, went to pick it up, it was the brake pedal switch......
Pretty sure I was 150% clear I was looking for the reverse light switch.
Won't likely get the car on the road for a few more days, sigh.........
Hello
I also discoverd problems with my reverse lights/reverse light switch.
First I replaced the reverse light switch and the reverse lights were ok. Some days later the reverse lights are not working.
Now I noticed a strange thing, sometimes my reverse ligts are working, some days not. Putting my 996 (with ignition on) in reverse, maybe after 20 seconds or so (different from day to day) the reverse light lightens up, but sometimes not.
I took out the switch out of the gearbox and pushed by hand, no problems, lights are working. I pushed in a small wire between the conecctor and lights are constantly on... Blubs are fine. When the reverse lights are not working (ignition on, gear in reverse) there is no 12 volt back at the connector at the lights.
I mounted a rear view camera this spring thats how I discoverd the problem. I have the rear view camera NOT connected and still the same problems.
I checked a fuse, according to the service/porsche-book at the drivers side, dont remeber the exact fuse number, but that one was fine
My thoughts; A ground problem should not be the problem, since with that wire in that connector lights are on. Could it be a bushing in my gear-linkage, so I am not hitting the reverse swicht correcly. To be honest, changing gears feels good, nothing fluppy or loose....
Anyone suggestions, what I could check/search for more? My old reverse switch was definetly not working.
996 Carrera4 X51 AeroKit 1999
Best regards Sebastian
