Humming Noise near gas cap
Basic Sponsor
Also a good idea is to check the condition of your gas cap seal/gasket. When it deteriorates, it can cause a vacuum issue as well as a whistling noise. If you take the cap off, you will see the gasket fairly deep inside the cap and you'll be able to see if the surface is smooth or has cracks/tears.
Mark/Pelican Parts
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
![](https://rennlist.com/forums/signaturepics/sigpic303_8.gif)
Captain Obvious
Super User
Super User
Found and tested the hard start problem. It is the purge valve in the engine compartment, left of the throttle body. Disconnected the throttle body side hose on the valve (thr rubber hose), then slipped a piece of rubber glove over the end of the valve and slid the hose back onto the valve. Did about a dozen engine starts, low RPM take offs and no sign of the hard start or noise from the filler neck area. Next step is to remove the valve and try to clean and bring it back to life.
Captain Obvious
Super User
Super User
After plugging the line to the recovery valve pulled the codes and one of them was P0446. So the ECU picked up that the valve was faulty too. I'm away from home so any further work on this will be a few days from now.
Yes, unplugging it while its closed will be a temp fix but will give you a cell. I was also getting a cel pointing to the issue before hand. The cel will go on after a short drive then after pulling up to a light. I foget the code.
[QUOTE=Imo000;10724790]Found and tested the hard start problem. It is the purge valve in the engine compartment, left of the throttle body. Disconnected the throttle body side hose on the valve (thr rubber hose), then slipped a piece of rubber glove over the end of the valve and slid the hose back onto the valve. Did about a dozen engine starts, low RPM take offs and no sign of the hard start or noise from the filler neck area. Next step is to remove the valve and try to clean and bring it back to life.[/QUOTE]
Pics if you open it up to clean it.
Captain Obvious
Super User
Super User
Took it off and tested it with a 12V cordless drill battery. It was closed and the it openned twice, after that it stuck open. So I poured in some paint thinner and popped the vavle a few times with the battery. Did this from both ends. This seemed to fix it. This engine had a failed AOS that the previous owner didn't fix for a very long time so I'm not suprised this valve got it's share of oil and made it sticky. The valve can not be taken apart to service it.
Thanks all for your advice. During these posts I had the car back in the shop. They ran the Porsche super computer against the car. And both valves were found to be not operating normally. Both valves (purge and one by vaccuum in engine area) replaced and lines blown out. Was so excited to get car back and not sound like I am driving an overpriced Dyson.... And then that damn sucking sound again
Called back and mechanic said possibly defective gas cap that is not holding the seal. Wish I could get out of this with just a new gas cap. Drama continues.... If I can't fix problem going to reach out to Dyson for sponsorship ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Yes there is a valve in the engine compartment that turns vaccume and on off to the tank. Mine was sticking open putting a lot of vacc on the tank making it so the pump couldn't pump the fuel.
The valve comes right off the TB and it is mounted right above the plenum rail on the left side. It is about 3" long and has a 2 wire connection. it has a quick connect that attaches it to the hose that runs up to the tank
The one on the engine compartment is connected to the drivers side of the throttle body and sticks out into the area above the alternator. Has electricle connector and vacuum line running through it.
http://www.pelicanparts.com/More_Inf...OEM&SVSVSI=915
Received 1,855 Likes
