I would get a little can of flex, solder past and smother the existing solder with it, although your solder had this in its core it may be burning off to soon and not going were you want it
Thanks, I'll try that.
Also, I used CRC brand QD Electronic Cleaner (quick drying) to clean and allowed to dry over an hour before soldering. If that's contributing to the problem, I wonder what cleaner to remove that.
Sounds like your soldering gun is not hot enough for the job. What is its wattage?
30 watt, max temp. 735 F.
I think you're right, after watching a couple videos. They also imply a bigger tip would help for the bigger joins, so I'll get that. Current tip is very skinny fine point. Gun package says "for delicate soldering jobs", so might not be capable. I'll try to borrow a bigger gun.
Yeah I just hit the motherlode of info. for this soldering gun (reviews on Harber Fraight site). Folks like the gun but the tip sux, so good tip replacements, usage tips, flux, etc.
I agree those look more like welds than solder. Hard to say with that much mass to heat up. Your best bet is to use a file and some sandpaper to clean the metal surface good. They need to be heat up real good to take the solder. It's entirely possible the metal is just too massive to be soldered.
