Dreaded IMB question, with a twist.
Recently I bought an 2004 C2 cab. It had a IMB caused engine failure which was fixed by the local Porsche dealer in 2012. My questions as a non-insider:
Is there a chance that Porsche put in an "upgraded" IMB to replace the failed one?
What is the chance that the new IMB breaks and would the LN upgrade be advisable at this point?
Rocky Mountain High
Did it require a new engine? That's the typical fix for an IMSB failure. It's most likely a single-row IMSB in the new engine, and not really upgraded. The LN Engineering IMSB would probably give you a little more peace of mind.
Basic Sponsor
How many miles were on your C2 in 2012 when the failure occurred?
Mark/Pelican Parts
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
How many miles now? IOW how far since the repair?
All M96 engines have an IMS bearing. Therefore all can have an IMSB failure, new , old, dual-single row, larger dia, LN, Casper labs, Pelican, etc...
Drive it enjoy it Change the oil every 5k miles.
DrBrain,
You are getting all of these questions due to the understanding that if an IMS bearing went bad, regardless of any catostrophic damage to the rest of the engine, the dealer would just pull the motor and put a new one in (provided that Porsche chose to cover the issue). I've nver heard of a dealer rebuldling an engine in house after a IMS bearing failure.
I don't know if they put in a new engine, "rebuild" is the term that the Porsche service manager used. It is entirely possible that they put in a new one. BTW, the repair was covered by an extended warranty.
All of the replacement engines put in by dealers were factory rebuilds, If I remember correctly.
I doubt the SM would write rebuild if the engine was replaced.
It is not unknown for a dealer to rebuild an engine that has suffered an IMSB failure as long as the engine is rebuildable. The factory issues guidelines the tech is to follow to determine if the engine is rebuildable.
I came across one such engine at a Porsche dealer. Besides the obviously bad IMSB the IMS was replaced along with one cam chain tensioner rail for the loose IMSB caused some excessive chain movement which damaged (but not severely) the rail (broke off some fragments of the composite plastic material these are lined with).
By 2012 Porsche only replaced a 2004 engine's IMS with the larger, single row, upgraded (post 2005) IMS shaft and bearing assembly. It is/was very rare for the dealer to rebuild an engine. Most failed engines were replaced with "new", actually factory rebuilt, crate engines.
In those cases there won't be many parts on a replaced parts list.
If the car had a Porsche rebuilt engine installed it will Have an "AT" in the serial number.
Like this: M96/03AT66565123
M96/03 = 3.6
AT = Factory Rebuild
665 = 6 cyl, normally aspirated, 2005
"AT", which is not the normal format, might stand for "Austausch", which means "rebuild" engine.
http://www.renntech.org/forums/topic...e-sn-decoding/
If you have the new, improved, larger diameter bearing it cannot be changed without complete engine disassembly.
I had a factory rebuilt engine put in my car by the Porsche dealer. The total number of pages was 2 because the part being replaced was the engine. It didn't come nearly close to 8 pages.
8 pages seems like engine was torn down and individual parts were replaced.
