Solution for those with a sagging rear-end!
How worn are your shocks?
I've seen other H&R lowering springs on c4s without issues.
Seems odd you would have to do something like this with H&R's. Eibach Pro-kits I can understand.
I made a set for my C4S. I turned a set of hockey pucks down to half their thickness and added a bore to fit over the shaft (matches the steel lower perch).
It’s not much more than it sounds. Good luck!
