996 Forum 1999-2005
Help! Low beams not workin
Old Jul 27, 2013 | 11:05 PM
Gmoneys's Avatar
Gmoneys
Angry Help! Low beams not workin
Parking and driving lights are working fine.
I open the fuse door but there is no way to tell which fuse is the one.
Any ideas what could be the fault?
The high beams only work when I hold the lever towards me or the steering wheel.
Thanks in advance.
G'
Old Jul 28, 2013 | 12:18 AM
DaveCarrera4's Avatar
DaveCarrera4
Might be the light switch, I understand they can go bad. Fuse is another good thought.
Old Jul 28, 2013 | 12:58 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
+1 on the headlight switch.
Old Jul 28, 2013 | 10:26 AM
Gmoneys's Avatar
Gmoneys
I just don't know which fuse to check.
Is it possible that part of the switch is working since parking and driving lights work?
Also is the more than one fuse?
Thanks!
G'
Old Jul 28, 2013 | 10:35 AM
skiracer's Avatar
skiracer
My guess is the headlight switch itself. Happened to mine earlier this year - very easy DIY w/ great instructions. Common issue w/ 996's.
Old Jul 28, 2013 | 12:16 PM
fpb111's Avatar
fpb111
Should be one of these folded up in the fuse box cover. If both are out +1 for switch
File Type: jpg
File Type: jpg
Old Jul 28, 2013 | 07:01 PM
sjfehr's Avatar
sjfehr
Nthing the bad switch; it's a well known failure item. The light switch is a fairly easy replacement, but it's a pricey part- just over $100, IIRC. If you're handy, you can dismantle it and repair it; probably just a dirty or bent contact.
Old Jul 28, 2013 | 08:59 PM
DaveCarrera4
Check Pelican parts for the switch, I think that is where I may have gotten mine. No wait, it was somewhere else, maybe sunset Porsche, in any case was around $80, and 15 minutes or less to replace.
DC4S
Old Jul 29, 2013 | 09:17 PM
Gmoneys's Avatar
Gmoneys
Thanks guys!
I just ordered the switc.
G'
