996 Forum 1999-2005
Tranny rattle and vibration issue need advice.
Old 06-27-2013, 04:18 PM
KrazyK
KrazyK's Avatar
Mac, I think one of his concerns was that someone machined the flywheel. I suppose none of us know at this time if this is a stock OEM DM flywheel or an aftermarket one. If its an OEM DM we all know machining or resurfacing is a no-no.
We are WAG'ing at this point but I have no rattle at idle or otherwise, clutch in or out but I also have all new parts including flywheel.
I dont think he would be over reacting to at least drop trans if he wants to inspect more closely. I thought he mentioned vibes and noise at other RPM's too but maybe Im wrong. I would still check into the shop that did the work and ask exactly what they did.
Old 06-28-2013, 09:46 AM
wlee69
wlee69's Avatar
Originally Posted by fpb111
Does the car have a light weight flywheel? Does the rattle change when the clutch is pushed in? Also check the engine mounts and the trans mount. New engine mounts could make a big difference if the current ones have leaked/gone "flat"
I still wouldn't rule out the engine mounts and that helping out as it seems like you are saying at idle you are hearing the noise (probably due to some vibration). If the mounts have never been changed (and its a '99) it a quick easy thing you should do anyways.
While I was doing my alternator a couple weeks ago, I also swapped out the mounts on my '01, and now at idle the car vibrates much less (used the passenger seat as my before and after test)
Old 06-28-2013, 12:17 PM
Macster
Macster's Avatar
Not sure where you got the resurfacing the OEM DM flywheel a no no. I've come across cars in for new clutches at dealers and in some cases the FW is sent out to be resurfaced.
As long as the FW's DM feature checks out ok and the tech can't find any other reason (excessively overheated, cracks) to reject the FW they're ok to reuse, with or without resurfacing.
Treated right they'll give good service life as the one in my 268K mile Boxster is an example.
Not all cars have as quiet a transmission as your car. Some can be a bit noisy but this is not a sign of anything really wrong. Just the normal differences between cars.
Also, a slightly rougher running engine -- as might be possible with an ill-advised exhaust system modification -- can exacrebate the rattle.
Thus given if the same exhaust was fitted to your car it might make as much noise as the OP's.
As for dropping the transmission I'm not at the car so I can't really offer any guidance other than to advise the OP to have a professional tech give a listen and if he thinks the noise warrants further investigation to go along with the tech's advise.
Old 06-28-2013, 02:50 PM
KrazyK
KrazyK's Avatar
Mac, I assumed you knew better. The info is straight from the manufacturer who builds them, LUK. I dont think youve seen any Porsche dealer having OEM LUK dual mass flywheels resurfaced. They just replace them.
Due to their design, LuK does not recommend resurfacing dual-mass flywheels.
Im not saying this is his noise problems, but it calls into question the repair shops competence.
Old 06-28-2013, 03:10 PM
iim1awh
iim1awh's Avatar
This is all so new to me that I am not sure if I am over reacting to a non-issue or if I have a real problem. I am more or less satisfied that the gear rattle is a common issue so I will monitor it to see if it gets worse. The vibration issue however is worthy of an expert opinion there a few local specialty shops that have good reputations both locally and on the forum. Seems a few $$ is well spent. from that I can get a good feel for what if any issues there are and what the best course of resolution is.
You guys have been great and i will keep you posted.
Thanks,
Andy
Old 06-28-2013, 03:49 PM
pfbz
pfbz's Avatar
Received 2,880 Likes on 1,532 Posts
My plan is to still drop the tranny and take a look at the DMF
If your going to drop your tranny to inspect the flywheel, are you planning on inspecting or replacing your IMS bearing? I am definitely not a IMS-gloom-and-doomer like many on this forum (cough, KK, cough), and don't usually advocate preventatively replacing them 'just because', but if the tranny is down, 2/3's of the work is already done and it might be worth either putting in the LN ceramic kit, the pelican kit, or source your own $20 ceramic bearing.
Originally Posted by iim1awh
I refilled the gear box with Redline 75W90 NS GL-5 just to get me buy until I drop the tranny in the next few weeks. I will order the good Porsche stuff for the re-install.
The Redline GL-5 gets lots of extremely positive recommendations from 996/997 owners, even more so from the track set who occasionally have 2->3 shift issues under high G / high RPM loads. It's what I plan on using on my next tranny fluid change, so I'm curious to hear back how it works for you.
The only real complaint that I've read about some other top quality but non OEM gear oils (e.g. Delvac) is that some folks have more 'cold shifting stiffness' than the OEM (999.917.546.00), which I think is a Shell product?
Don't know where you live, and reasonably certain your not going to get much cold weather anytime soon, but I say stick with the Redline and give us an update!
Old 06-28-2013, 06:21 PM
jasper
jasper's Avatar
Here's a thought.
The symptoms described sound a whole lot like the kind of noise I got when I replaced my otherwise fine DMFW with a AASCO LWFW. Prior to this exchange there was no transmission noise - none.
I wonder if the car had a LWFW already and that was what was resurfaced. I can't see how resurfacing a DMFW would cause noise - the vibration dampening properties of the DMFW wouldn't be affected at all.
Old 06-29-2013, 01:19 AM
fpb111
fpb111's Avatar
"1. The gear rattle is only present at idle with the clutch disengaged, engage the clutch and there is no more rattle."
I'm a little slow please help me understand this sentence. "Disengaged" = foot on the clutch - pedal to the floor or pedal up foot off pedal??
You might be looking at the effect and missing the cause.
Your car calls for plugs @ 30k intervals. When was last plug change? Also check the coils for cracks while you are in there. If the engine is running slightly rough it will aggravate "normal" gear clatter.
Also a louder exhaust will cause more vibration in the car. Different bits will vibrate when the pressure waves from the louder exhaust hit their resonate frequency.
I noticed this in my car when I did the first style PSE/Gundo Hack/Fister mod on my car.
Pic 1 is the first hack done like Porsche's Sport Exhaust (PSE) without the OE vacuum silencer switch
Pic 2 is louder and as I understand it the hack Fister does on all of the 996 cans now.
Old 06-29-2013, 01:52 AM
iim1awh
iim1awh's Avatar
Let me summarize
Gear rattle is present when when foot off clutch.
Vibration most present when foot clutch depressed to floor and RPM at 3400.
Plugs where replaced at 60k by previous owner.
To be honest the more I think about it the vibration issue presented itself about the same time I installed the Fisters.
Andy
Old 06-29-2013, 01:57 AM
iim1awh
iim1awh's Avatar
As a note the exhaust mode fister did for me looks like pic #1
Old 06-29-2013, 11:16 PM
fpb111
fpb111's Avatar
As Macster said: "Some gear rattle at idle is normal. With some trans louder." If you don't have whine when under pressure accelerating/driving trans bearings are probably good.
If the rattle goes away with clutch pedal on floor ?probably? not DMF.
You wanted louder you got louder. Go enjoy it.
Old 06-30-2013, 02:24 PM
Macster
Macster's Avatar
No where in my Porsche references can I find any warning about resurfacing the dual mass flywheels used on Porsches.
From LuK's web site, I did come across a reference to refacing that cautions: Scoring, glazing, and/or gouges indicate that the flywheel has been overheated, and these must be removed, however they should never be refaced beyond the tolerances laid down by the manufacturer.
In another document at the LuK site, I find that as is the case with with other items, like oils, the OEM refers one to the vehicle manufacturer for the last word on the use of the item.
"What should be considered when installing a DMF?
• Observe the specifications of the vehicle manufacturer!"
But your info does raise some questions.
Maybe the techs are going against the official guidelines and resurfacing when they should not be?
While this is certainly a possibility I find this hard to accept as generally they are more conservative. A component failure from unsanctioned resurfacing means the dealer eats the cost of the subsequent repair. For a dealer to go directly against what the factory recommends would I think call into question the accreditation of the dealer.
Besides there is the profit margin from a new flywheel vs. just a resurface, unless I guess as some would offer up and that is the customer is being charged for a new FW when the old one was just reused after an unsanctioned resurfacing.
I'll keep this in mind and see if I can learn more. I can use an excuse the fact my Boxster has so many miles and is getting close to needing a new clutch and should I budget for a new FW at the same time.
Old 06-30-2013, 02:49 PM
Macster
Macster's Avatar
Let me summarize
Andy
It is good to see a summary to make sure we are all on the same page...
Gear rattle of a mild sort that then has the rattle in the realm of they all do that can be present with the clutch disengaged. It should go away when the clutch is depressed.
Whether it comes back after the clutch is released again right away is questionable. In my experience if I do nothing else it does not. If I rev the engine then sometimes as the engine slows to its normal idle speed the noise comes back.
Revving the engine with the clutch pedal depressed subjects the bearing to extra and unnecessary wear and tear and as I like to avoid unnecessary wear and tear I do not do this. Any revving of the engine is made with the transmission in neutral and the clutch engaged, the clutch pedal fully released.
Thus I can't say if what you feel is normal or not. There are obviously times when driving my cars that I engage the clutch certainly with rpms in the range of 3400, or below or even above, quite a bit above. But I notice no vibration or signs of anything amiss.
It could be your car has a less smooth release bearing or one that is perhaps going bad. Not a diagnosis just a thought.
My only experience with a failed release (throwout) bearing is it was fine, no symptoms, until I depressed the clutch to start the engine -- as I had about a zillion times before -- and upon the engine starting what proved to be the throwout bearing emitted a piercing squeal and did so every time I depressed the clutch as I drove the car to the dealer to have what proved to be a failed throwout bearing replaced, along with the other clutch hardware.
I'm not at your car and I can't experience the severity of the symptoms to know if they are within what could be considered normal or not normal and thus suggestive of a problem.
So this vibration at 3400 with the clutch depressed I think needs a professional's attention if nothing more to say that's normal and to have someone tell you to stop doing that.
As for the exhaust system... The change to the exhaust system can affect the engine/drivetain vibration harmonics.
The engine/exhaust/drivetrain is a carefully tuned assembly to deliver acceptably good levels of performance -- we all are aware of this -- but to also deliver acceptably low levels of NVH (noise, vibration, and harshness). This sometimes we forget when we go making modifications to this assembly.
Does the vibration appear at the clutch pedal if you just place your foot on the pedal but do not put any pressure on the pedal and rev the engine to 3400 with the rest of the conditions the same and the transmission in neutral?
Old 07-01-2013, 11:36 AM
KrazyK
KrazyK's Avatar
Mac, just so you dont think I just make sh#$ up this has been discussed on this forum before and is stated on several LUK / clutch manufacturer websites. LUK does not recommend resurfacing ANY of their DM flywheels. LUK has a really nice PDF that explains a lot of info.
Straight from LUK's "Clutch System Diagnostic Guide"
dual-mass flywheels. For some applications LuK offers solid
flywheel replacements for dual-mass designs. Engineered
as bolt-in replacements, LuK RepSet and solid flywheel
replacement options provide increased torque capacity.
Many include larger diameter clutches than the original
equipment.
I wouldnt be surprised if the OP's DM flywheel has been replaced with a solid flywheel, hence the gear rattle and vibrations. He wont know until he drops the trans.
Old 07-04-2013, 12:44 PM
Macster
Macster's Avatar
I never suspected you made things up.
I too found the info at Luk's site you posted.
But I again scanned the factory manuals I have and no where did I find any caution against resurfacing the flywheel.
Certainly Porsche is not shy about cautioning against wheel repair, non N-rated tires, not reusing some fasteners or other hardware, even spelling out how much tire slippage on a wheel is permissible. I mean almost every page has at least one caution, warning, or note on it regarding what is proper and allowed or not allowed.
So it is hard to imagine Porsche failing to put something in the manual about not resurfacing DM FWs if indeed this was a no no.
There might be a separate document that does caution against resurfacing the DM FW but I have not seen it, not been made aware of it.
Anyhow, my Turbo -- just short of 110K miles -- is due to be serviced (oil/filter) very soon, maybe Friday if the dealer can fit it in, and I intend to bring this up when I drop the car off as my Boxster is getting close to needing a clutch. Well, not that close but with its miles I think a discussion about a clutch job would be timely.
Quick Reply: Tranny rattle and vibration issue need advice.
