Clay bar treatment
#31
I clayed my car a few years ago, and waxed with Rejex about a year ago.
Last weekend, I wanted to do the same, so I washed the car and dried it - and it was so clean and shiny, I said the hell with it and didn't clay it again.
Kind of like the Fonz, when he goes to comb his hair, and decides it's perfect and walks away!
#38
It get really hot and humid in Houston, so the best time to do it and be able to take your time is in the rain. plus you don't have to buy that over priced spray that is only used as a lubricant. A light rain works best and feels pretty good too.
#39
If you are removing paint with the clay bar there is something wrong. I have been polishing cars professionally for 20+ years and have never had clay, even the most aggressive clay, remove any mils of clear coat. I measure the paint on every car I touch and have never lost any from clay. The P21s paint cleanser is a mild abrasive and that will remove very thin parts of your clear over time.
The clay is simply removing the bonded contaminants from the surface of the paint. That is why the paint is smooth afterwards.
Just my opinion. YMMV.
I agree that the P21S polish is mildly(very mildly) abrasive on bare paint. However, the way I use it, to remove the old wax on the car, is VERY easy on the paint.
#41
What? This would be the equivalent of using plain water in a spray bottle as a clay lube. Not recommended IMHO. The "over priced" lubes have special polymers in them which help reduce friction and consequently, potential scratching.
#42
Yeah, im sure it does...and bottled water is way more healthier to huh.. even though it comes right out of the tap in Atlanta for the most part. You keep buying it and ill keep doing it this way... again, 7 years with my old outdated clay bar and still looks new.. I swear, some of you people over think the smallest things.
#43
I would love to see some pics of your 7 yr old claybar along with your 1300+hp monster. The only thing I have older than 7yrs besides my 996 are a couple underwear I only wear on "special" occasions.
#44
The last time i looked at clay bars I caw was white and that had been some years ago..I keep this in my shop fridge when not in use.
Yellow car is a Iron block 346 CI with F1A prochagrer making 26 psi boost with a whole lot of come get you some..
Red car is a 427 CI aluminum block with a F2 cog drive at 24 psi boost...pretty much a street ride
Anything else you like to see??? I would really like to get back to the OP's topic... as its really is only fair. I was just trying to voice what i have done and has worked for me..
