996 Brakes...
They can be reused if the warning light is not on, but they do occasionally break on removal.
My wear warning light just came on yesterday. Rears are worn. I ordered Mintex pads and new sensors. Rotors have almost no lip. I called machinist and he said he can turn drilled rotors. If the rotors can clean up and stay within 22.6 mm minimum thickness, I think I'll be good. I know that turning rotors on these cars is debatable so I'd like some input from anyone having bad/good experiences on using machined rotors. I'm also using new caliper bolts as recommended.
I called my mechanic buddy and as per fpb 111, he advised that I just change the pads unless I have pedal surge which I don't have. So, I will just change out the pads and the damaged sensor.
