Any recommendations on a low profile floor jack?
There are threads with this topic before. I use an OTC aluminum jack OTC 1532 2-Ton Capacity Aluminum Racing Jack : Amazon.com : Automotive You can get one with a similar spec but cheaper at harborfreight. I like it because it's low enough for a non-lowered car and light enough to carry and move around easily @43lb. The other best bang for the buck is the Arcan XL35R jack from Costco (~$99). Good even for lowered car, very sturdy but heavier @100lb.
The Penguin King
I have OTC Aluminum Racing Jack Kit . This is a really nice high end all aluminum floor jack. You tend to get what you pay for here. It is very easy to move around and you can get it up to full height in just 5 or 6 quick pumps. What a really nice design here by OTC products on this two-ton floor jack.The best thing about this jack was how incredibly lightweight it is. It is made of mostly heavy duty aluminum construction
while I don't consider OTC tools high end, or even medium end for that matter, I can finally sleep at night. This question has been bugging me since 2013. I can't tell you how many sleepless nights have past, but thankfully you came along and solved my problem. I sure others will thank you for scratching that seven year itch
I purchased the 3 ton Low Profile Steel Heavy Duty Floor Jack from HF last year. Its a great jack especially at the price point. In fact, I purchased a second jack a couple of months ago when I replaced my AOS.
Another vote for the HF low profile steel jack ... I picked up two for $59 each a couple years ago. They fit easily under the car. No complaints so far.
Love these necro-threads...
To update post #4, my HF alum is now 14 years old and still going strong...
I have a craftsman low profile aluminum jack. Maybe 2 ton? Not 100% sure. I've probably had it 10+ years and believe it was about $200 new. Its been OK but not perfect. My biggest complain is that the piston the handle pushes down constantly gets stuck on its way back up about half way - really frustrating and not what I'd expect for the price. Not sure if this is a function of the spring not being strong enough or something else. Now, its also started to leak.
It also has a single, really wide, roller on the front that is a bit annoying because its more prone to getting caught on little pebbles when rolling it around. It looks like they've revised that design though.
When these jacks start to leak oil and cease lifting the car, is there any way to refill, or are they just trash at that point, and time to buy a new one?
The Chinese jacks are pretty much throw-aways when they are done. OTC, HW, AC, Snap-on are all rebuildable. Here's what I bought to get under my GT3 as the others weren't low enough:
http://www.pelicanparts.com/cgi-bin/...iption=ac+jack Part #: TOL-13HLQ
A big difference in jack quality is being able to modulate lowering speed. Cheap jacks tend to be on/off and the better jacks will let you control how fast your baby comes down.
i just got one a few weeks ago and I find that if you try to control that dial when the arm is straight up its hard, but if you have the arm lowered its far easier to gradually let it down
for the money its well worth it though, its so much better than the other jacks I have had, and you dont have to worry about anyone stealing it because its to heavy lol
